hello, I see spray adhesive beening used by some members to adhere the plans to timbers to be cut to size, on a jig saw, or what ever. what brand do you use or a spray that doesn t stick to much....
I am not using a spray, but the obligatory Rubber cement Fixo-Gum by marabu - can be removed easily afterwards without any residues - with a spray to spray all areas around and not only the area you want to ....hello, I see spray adhesive beening used by some members to adhere the plans to timbers to be cut to size, on a jig saw, or what ever. what brand do you use or a spray that doesn t stick to much....
I have used a spray adhesive for many years to attach paper patterns to wood for chip carving. I use Scotch Spray Mount Repositionable Adhesive in a red and blue can (the last time I bought it). Make sure it says Repositionable Adhesive because the also sell spray that is not repositionable. To remove the paper from the wood wipe paper generously with mineral spirits And the paper will peel off the wood. The mineral spirits will dry with no affect on the wood. If I’m in a hurry, I use compressed air to dry the object, if any adhesive remains on the wood it can be removed with Lacquer Thinner, again with no harm to the wood. I hope this helps.hello, I see spray adhesive beening used by some members to adhere the plans to timbers to be cut to size, on a jig saw, or what ever. what brand do you use or a spray that doesn t stick to much....
Use the Elmers washable school glue. Glues great and comes off with water or falls off in 2 years when the glue dries out.hello, I see spray adhesive beening used by some members to adhere the plans to timbers to be cut to size, on a jig saw, or what ever. what brand do you use or a spray that doesn t stick to much....
