I'll try anything once...!Experimenting is a large part of our hobbies and ideas come in at unexpected moments. Rich
I don't think I have one of those...either of them. That's one of the reasons I'm on this site--to learn from the masters.Were you using a spur drive center? Center finder?
Where would you get one of those and what might it be called? Is it the same thing that Donnie called a "center rest"?I use a sherline and they have a gadget that holds the spar and prevents the wobbling without scarring the wood. It is triangular shape with three adjustable legs.
![IMG_4112[1].JPG IMG_4112[1].JPG](https://shipsofscale.com/sosforums/data/attachments/204/204929-5152e2f87f0714495ecee2151409b153.jpg?hash=UVLi-H8HFE)
That explains it very well. Do you use chisels?View attachment 220647
@Vfordyce , in the above pic on the left is a spur centre and the right is a live centre. Spur centre is used in the headstock normally when trying to turn square or odd shaped material round. Live centre is used in the tail stock to steady or support the material you are turning.
If you are using a dowel use a three or four jaw chuck to hold the dowel. Put dowel into chuck and if possible push it though the headstock until there is only a small amount left sticking out of the chuck. Tighten the chuck up a little just so that the dowel won't slide out, bring up your tailstock, with the live centre mounted in it, and mark the centre of the dowel with the point of the live centre. Now loosen chuck, move tailstock back and pull out dowel to desired length. Tighten up chuck and slide tailstock up to dowel making sure the point of the live centre is located in the mark/hole you previously made. Tighten down tailstock and live centre then start turning/sanding your wood!! The two block method previously mentioned is a real good system!
As the admonition, "Fool me once, shame on you. Fool me twice, shame on me!"I'll try anything once...!
turning chisels to shape dowels. Plus, at such small diameters, if the cutter catches on the wood grain EVEN ONCE, you'll snap the part anyway. Sanding the material away is best. You don't have that much material to remove anyway, so using a risky cutter is not a good idea. I was using a stationary live center. Its a pointy thing.Were you using a spur drive center? Center finder?
A live center is great, but you don't need a center spinning on ball bearings to turn dowels into masts. You can use a non-spinning center as well. See the drill press picture I posted earlier. The center is simple clamped in a vice, which is so heavy relative to any force applied to the dowel that it never shifted while working. Even a small dimple made by hand in the center of the end of the dowel is enough to hold the tip of a live center in position. I placed the wood into the metal lathe with almost nothing protruding from the chuck, and while it was turning, pushed a dimple into the wood by screwing the live center mounted into the tailstock until the tip crushed about 2mm into the wood. Don't push in too far or you'll split the dowel. I can then take the dowel out and place it loosely in the drill press chuck, pressing the end with the divot onto the live center at the bottom lightly while I tighten the chuck. It While sanding, watch to see if the dowel slips upward into the chuck. If that happens, you could loose support of the live center at the bottom and snap off the piece. If chuck gets loose, stop and tighten it up before resuming sanding.View attachment 220647
I may be old school technique and age but I prefer to hand sand and check the diameter frequently. Not being in a hurry it is not a problem but provides the activity and focus that I want in this hobby. Just a personal thing as every time that I try to hurry I end up having to do it over . . . and over. . . and again. . . etc. RichA live center is great, but you don't need a center spinning on ball bearings to turn dowels into masts. You can use a non-spinning center as well. See the drill press picture I posted earlier. The center is simple clamped in a vice, which is so heavy relative to any force applied to the dowel that it never shifted while working. Even a small dimple made by hand in the center of the end of the dowel is enough to hold the tip of a live center in position. I placed the wood into the metal lathe with almost nothing protruding from the chuck, and while it was turning, pushed a dimple into the wood by screwing the live center mounted into the tailstock until the tip crushed about 2mm into the wood. Don't push in too far or you'll split the dowel. I can then take the dowel out and place it loosely in the drill press chuck, pressing the end with the divot onto the live center at the bottom lightly while I tighten the chuck. It While sanding, watch to see if the dowel slips upward into the chuck. If that happens, you could loose support of the live center at the bottom and snap off the piece. If chuck gets loose, stop and tighten it up before resuming sanding.
For those of use with less experience with that method, turning the parts is better for maintaining concentricity.I may be old school technique and age but I prefer to hand sand and check the diameter frequently. Not being in a hurry it is not a problem but provides the activity and focus that I want in this hobby. Just a personal thing as every time that I try to hurry I end up having to do it over . . . and over. . . and again. . . etc. Rich
I have the same drill press also. How do you hold the bottom of the dowel to keep it from wobbling?If you don't have a lathe, use a drill press!
And remember, there are collet systems to hold dowels and rods while turning.View attachment 220647
I've always used either a plane. chucked a spar in a drill, or sandpaper, but I recently bought a small Proxxon lathe and it is much easier to use. It came with a variety of collets which take care of my spar needs. There is a hole in the lathe that lets you insert a long spar, taper half of the spar, switch it around and then taper the other half. I also just received (but have not yet tried) a chuck that replaces the piece that supports the exposed end of the spar. This should be helpful with small diameter spars. I use sandpaper which I fold around the spar and this collects almost all the dust.
Thank you!I use a lathe on the larger masts and yards. I have a 900mm centre to centre 10 speed lathe which is nice for what I need. The main thing is to make sure your tools are sharp and then sharp. I found that I had wobble on smaller diameter dowels if it was set to tight or turned to fast. Have turned down under 2mm on yard steps but you have to be patient and as I said sharp tools. Walnut I found was best to turn with some maple as well. The other timbers I have tried are Jarrah and gum they turn well as well. Will be doing the Berlin after the Bounty and its supplied masts are square so will definitely use the lathe to turn them down
