This is the first build log I have done. Since I’m a newcomer to POF kits, and since so many others have set out their techniques in such great detail already, the plan here is to post my progress accompanied by questions as they arise. I appreciate everyone’s help as I move ahead with this build, as always.
After all the helpful tips about assembling the frame pieces, I started with frame #8. Was able to assemble the frame using the template and the clamping techniques that others have described.
The angle of the bevel and amount to remove on this first plank took a bit getting used to, as did the best way to remove wood from the plank. I saw the various techniques that others had used, everything from using a dremel to only using sandpaper by hand.
I stayed away from the dremel for this first plank, used a diamond file followed by 220 sandpaper.
Happy with the result on this first frame, not perfect but the others to follow should improve.
everyone....something a wee bit "off-topic".....sort of. For your Bluenose model display....... The Royal Canadian Mint is introducing a new Proof Silver Dollar in commemoration of the 100th anniversary of the launch of the original Bluenose:
