The Glory of Catherine, 66-gun sailing ship, by Mr.Deep [COMPLETED BUILD]
The Day of the Black Sea Fleet (or the Day of the Black Sea Fleet of the Russian Navy, the Birthday of the Black Sea Fleet of the Russian Navy) is a Russian holiday celebrated annually on May 13 in honor of the creation of the Black Sea Fleet of the Russian Navy.A festive salvo. Upper deck guns. I also finish hitting the nails in the underwater part of the hull. For a change, I make mars platforms.
Today I spent the whole day getting nails and skinning, skinning,skinning.Sanded and sanded again.The underwater part of the hull took about 4,500 tiny copper nails.Well, I immediately went through the stain under the oak tree.IMG_20210519_213833.jpgIMG_20210519_213845.jpgIMG_20210519_213923.jpgIMG_20210519_213941.jpgIMG_20210519_213952.jpgIMG_20210519_214017.jpgIMG_20210519_214024.jpgIMG_20210519_214041.jpg
This are really a lot of nails !!!
Which size does these nails have? And where did you buy them?
Several members are looking for a source of small size nails ..... therefore the question
Это действительно много гвоздей !!!
Какой размер у этих ногтей? А где ты их покупал?
Некоторые участники ищут источник гвоздей небольшого размера ..... поэтому вопрос
Уве, привет. В России ногти обычно делают сами. Накатка тупого ножа на модельном коврике из нужной проволоки. Это не быстрый процесс, но он того стоит.
Uwe hi. In Russia, nails are usually done by themselves. Rolling a blunt knife on a model rug made of the desired wire. It's not a quick process, but it's worth it.
Uwe, Alexander is right. I don't roll nails. I take the wire of the desired diameter. I bite into pieces of 3-5 mm. Then I pinch the tip with thin mini pliers. With a small file, I grind off the top to get a smooth, flat cap at the nail.
Hi Mr.Deep, I use this exact method on my Le Coureur. Works flawlessly. Your nail work looks very good.
Started a new project.View attachment 170508View attachment 170509View attachment 170510View attachment 170511View attachment 170512View attachment 170513View attachment 170516of the first line of the Russian black sea fleet. One of the five ships of the same type that were built at the Kherson shipyard.The construction will be long.The drawings of the paper model of the firm "Paper modeling" are taken as a basis"The patterns were on a scale of 1: 100.Zoomed in to the 1:72 scale.Drank all the frames, keel, longitudinal connections.
Hallo @Mr.Deep
С днем рождения коллега! Здоровья и успехов в новых постройках! Birthday-Cake
Well, I came from the dacha, you can show that I made a new one. A little, of course, but there is something there. I put the foretop and the mainsail. I made outboard ladders. I started making the stern, at the same time I put the platforms on the bulkhead of the bikged.
IMG_20210703_211926.jpgIMG_20210703_211931.jpgIMG_20210703_211939.jpgIMG_20210703_212003.jpgIMG_20210703_212017.jpg
Again, my Glory of Catherine the 72nd Put the guns on the main deck.I tied up the hoists, it remains to throw the bays on the puluba. I inserted the barrels with glue into the ports of the closed deck.
