Just saw your post - brings back memories of my time sailing on a vessel with a 'Triple Expansion' steam engine. Just an idea; soak some thread in PVA, then lay it where you want to simulate the weld.I am building a model of an open steam launch. The original hull has been made of steel by welding, leaving the seams of steel plates visible. I wonder how can I simulate these horizontal welds at my hull like in attached photo?View attachment 220957
This is worth making a note of for future reference.In plastic modeling you would lay a length of styrene rod or stretched sprue in the seam and soften it with Tamiya Extra thin or any MEK plastic welder then work the bead with a knife to simulate the bead. Id use putty of some kind that can be worked. Mask the bead thickness so the putty stays exactly where you want the bead to be then work it with whatever tool you can to simulate the bead.
Thank you for the information.You might check out Archer Transfers. They have a variety of surface detail transfers including weld beads. I've used some of their rivet transfers on my model RR
use a syringe like a cake piping bag. id probably go with epoxy since its more resistant to water plus its tougher once cured.Thanks guys for nice suggestions. Superglue and baking soda might work, but problem would be how to apply it so that the seam has even width and it would build a nice curve along the entire hull. I am still open for more suggestions.
