Any problems with the boxes supporting the guns falling off?
**VIEW THREAD HERE** |
had two fall off inside.... major surgery.Any problems with the boxes supporting the guns falling off?
Ugh! How does one make sure they don't fall off inside?had two fall off inside.... major surgery.
Hopefully, you glued them well as you were putting things together. I knocked mine off during second planking....(still working on 2nd planking, almost done) I was using push pins to hold the strips in place and as I was pushing on the pins i hit the boxes and knocked them loose. Actually, i didn't know i even did it until later. Fortunately, I cut out the approimate size of the box, retrieved and put back together. How far along are you? In reference to seating the guns,,, take a dremel with a burr and ream it out a little.Ugh! How does one make sure they don't fall off inside?
They are attached from the inside. Glue being the only retention.Can you show the image how they are supposed to attacheded?
Hello VicUgh! How does one make sure they don't fall off inside?
no worries VicSorry to highjack your thread, Gilbert.
HI VicGilbert, did you test fit the bowsprit. It seems the front piece that holds the cannons sits too high. I dry fitted my bowsprit at that height and the angle of the bowsprit seems off about 30 degrees or so.
Hey, Vic, You may use rivets (after you glue), I suggest using based glue. It holds reasonably strongJust glue the near edges to the strip of gun ports.
What is based glue?Hey, Vic, You may use rivets (after you glue), I suggest using based glue. It holds reasonably strong
LOL...Not sure what happened, but it was supposed to be PVA-based glue. For all the structural\framing work I use Elmer's Max, highly recommend it! The glue bonds are stronger than wood.What is based glue?
Excellent work Gilbert. Hopefully I will be able to start back by the end of the year.Hello all,
Moving now to the starboard side
I worked on the channels, dead eyes and chains as well as the first row of cannons (total 14)
Next step will be the lower row ...
"end of year"? I've been trying to follow?Excellent work Gilbert. Hopefully I will be able to start back by the end of the year.
I am taking care of my wife and it’s a full time job. Hopefully by the end of the year she will be better."end of year"? I've been trying to follow?
