Model VICTORY by Deagostini, scale 1/84 [COMPLETED BUILD]
Hello everyone. Something I have not written or shown anything for a long time. :rolleyes:
Made some of the deck flooring amidships. Part, because the rest will not be visible, and this section is visible through the front entrances.20210823_193101.jpg20210823_193048.jpg20210826_213155.jpg
on a part of the deck I made markings for the dowels and installed the frame of the admiral's entrance on both sides.
Gondek and midship will have closed cannon ports, so I did not cut them (ports). Then there are full-fledged ports. And here the dimensions from the magazine and Anatomy do not converge at all. To do something right-like, I first set up some of the infill between the frames at a level just above the deck. On these blocks I put the lower part of the gun port. I had to assemble the gun in order to correctly set the height of the port. The bar to the left of the implement is the template for the weapon ports. I will use it to make port frames (such an idea). Well, I also fiddled with the case a little more.20210826_213242.jpg20210826_213330.jpg
Witaj
Świetna robota po masz miejsce po kładzeniu się tak samo jak teraz Trzymam za Ciebie kciuki Aleksander powodzenia.
Pozdrawiam Mirek
Hello everyone. Thanks for your support and comments. I was away from the monitor for a week, so I didn't do much with the model. Made the pins for the deck. I had a strip of 1x2 mm pear, turned it on a cone on a grinding machine, greased it with PVA glue and inserted it into the holes. I cut off the excess. It turned out like in photo 3
