- Oct 28, 2018
Good plan Henk, you’re doing great work!Yes
I think so too Heinrich
A difficult point will be when I place the frames in the mold to get them into the keel easily.
I've made the cutouts fairly tight for the view for the open part.
So a lot of time will be spent on the frames.
Go for quality over quantity
Couldn't this be caused by the perpendicularity issue you have? One frame, not sitting at right angles could cause the keelson to shift either forward or aft. And then the issue gets aggrevated by the tight fit of the frames.In the mould, I had the keelson fit in its entirety.
If in the middle part, it does not connect.
This has to do with the fact that the other frames have become slanted ??
As mentioned, the legs connect flush to the base plate, and the noses are in the keel.
Solves this problem if all frames are straight, the logic escapes me in this
Ha Johan,Couldn't this be caused by the perpendicularity issue you have? One frame, not sitting at right angles could cause the keelson to shift either forward or aft. And then the issue gets aggrevated by the tight fit of the frames.
I think I would hold back as long as possible on gluing any frame until having a satisfactory dry fit.
Still, it's starting to look like a hull...
Kind regards,
Johan
Er een nachtje over slapen helpt ook vaak erg goed...Ha Johan,
Yes it must have to do with the squareness
All frames are now back in place and the problem is not solved yet
Do something else for now, and let it sink in
Hi Henk,Ha Johan,
It’s good to read you have some ideas to build it up, in a way that gives you confidence, Henk.Thanks for all the support guys
By now I think I know what's in the way
I've filed the recesses in the mold a bit to make the tight fits, so that they stay in place and relatively easy to remove without putting a lot of pressure, to prevent breakage
Frame 49 was 99, ....% square when I placed and also the middle frame
Because the recesses in the mold are no longer square, everything pulls skewed and furthermore skewed towards the middle
Frames 1 to 6 are nice perpendicular
I will remove the frames again make the recesses a bit bigger, and place the frame by frame with a piece of paper in between to clamp that is also possible
And check them frame by frame with the keelson
For this I had given the few slightly too large recesses a knife point with your glue and then filed them out again.
So all in all I did some thinking and spent a lot of time on it In retrospect
I should have done this differently, but some learning moments
So I'll take them out later, only continue when everything is a bit more perpendicular, I'm already so far that I know this will get in your way soon
@Dean, I had thought about auctioning the end of the frames a bit, but decided not to, to avoid breakage
I got a number of accounts added and my table is free of all frames again, so spend some time on that again, and on my sub
So the next update will have to wait a little longer![]()
This seems like a sleepless night well spend...Thanks for all the support guys
