About fifteen years ago I "scratch" built an POB RC version of the Cicely, an early 20th century schooner. The original had composite construction, iron frame with wooden planking. How would you go about truly scratch building something like that?
...then it is pretty much only one choice. You will have to build an iron frame and use composite constructions. Also, you may consider using the timbers actually used for the build. To better help you with your question\s, can you define a 'full-blown' scratch build?Yes, but then it's not what I would consider a full blown "Scratch build"
So the real question is: will you keep your frames open? Then, it makes sense to made frames the way they are built. We do have many modelers on this forum making POF (Plank On Frames), where frames are built the way on the actual ships.As close to the real thing as possible. So I would have to make iron frames or at least a reasonable facsimile. That's basically what I was looking for. I'm wondering if someone has done this before or if this kind of construction is avoided like the plague. I'm not sure if I can build it anyway. When I built it I contacted the Scottish maritime Museum and all they had was the deck plan. I got the lines from a picture of a picture in a magazine.
I know only section models to show the typical structure of composite hullsI guess I don't explain myself well, sorry. What I'm wondering about is if composite ships are often modeled and if so how do they make the frames.
www.modeltrainstuff.com
