- Sep 23, 2018
Since we processed all the members in the list, I suggest you contact @Trident Model model directly in PM. He will provide you with all instructions for your successful purchase. BTW, I tagged Trident Model in this reply. Good luck, Christos!How can I get such a kit?
The kit is $350 plus shipping around $100Im waiting to be contacted about this kit, do you mind sharing how much you paid for it?
Good question, Peter. Your observations are correct, the doors are a bit smaller for this scale and don't presentable, IMHO. Also, you would need to make the door frame first, so it will look correct. As for the walls, they should, IMHO, be cut as individual planks and glue together. In this case, the charred edges are not a problem and will help represent individual planks better. Take a look at some tests I made sometime back.You can see: the door doesn't fit. Now I have no problems with that as I can easily scratch build a new one, but the question is: Are we supposed to leave the bulkheads as they are and simply attach the square wooden timbers to these? This would leave us with bulkheads that have gaps between each planks which I don't like at all. Besides it would be near impossible to remove the charred edges between each plank.
