Plank bending question
Central Florida
What’s the general consensus regarding different fluids for softening wood prior to heating and bending. Water, alcohol or ammonia. If alcohol, what percentage. I normally use 95% for other things.
TIA,
Ron
TIA,
Ron
I steam the woods when possible then clamp in a jig or form while they dry.
Phil,
can you give me some specifics on your setup. What’s the steam source and what is the circular object on the top of the of the steam box.
circular item is a oven thermometer. the steam source is in the picture to the left of the box. i bought it at Woodcraft. it comes with the hose and fittings. its the Earlex steam generator. uses distilled water.
TIA,
Ron
This may be cheating but I have used this tool to put grooves on the backside of the plank to get the bend I want. Practice with some scrape as to how many grooves and at what depth. Got the tool at Model Expo
The Blank bender from Artesania Latina is working with the same principle - good idea and working well - especially for the first planking on a POB double planked model
Phil,
¿Puedes darme algunos detalles sobre tu configuración? ¿Cuál es la fuente de vapor y cuál es el objeto circular en la parte superior de la caja de vapor?
Las vaporetas de limpieza caseras van fenomenal, las planchas de vapor, hervirlas en agua, etc
Planks seldom bend in one plane only (apart from the upper hull planking)
Below a wale the plank needs to curve in 2 planes and , often, twist also. I can't speak for bending walnut veneer as I only single plank usually with maple but I also use basswood if a hull is to be painted. I find that water is all I ever need to soak. Most, if not all jigs, will not give the shape required to fit a plank. I always securely clamp the plank into it's intended position on the hull and allow to set. The result is a complex shaped and twisted strake ready to fit without splitting or straining the wood and without any (distressing) buckling.
I have also used the Artesania plank bending tool with total success. It works easily every time. I am nearing the end of building the double planked HMS Victory by Caldercraft. Every plank was bent with this tool with maybe 6/7 planks which split. I tried steam at the beginning but at my age, 78 I could be gone before the first planking was done.
I just wet the plank and bend it on a plank blending tool. I can’t remember where I saw the idea, but the difficult bends I make a form the same thickness of the plank, soak the plank, then bend it around the form, clamp it down and use a tiny steam iron to iron it. Works great. Thank you to whomever wrote that article on using a steam iron.
I guess I should not offer any ideas as it seems most has been covered. But, I am old school in the fact that I run very hot water on the plank for about 15 seconds or so. Then I have a nice plank bending tool that came with a maple template that has preset curves in it.
If I am doing something that is really thick like a beam then I will bend the beam with my hands / fingers under the warm running water until the desire shape. Then I will take some push pins and secure the "shape" down on the bench until it dries. I usually slightly overbend it as it will have a tendency to relax some.
It seems that I saw either a youtube video or someone on this site that homemade a steaming chamber. This way, the length was customized. If I happen to find that video, I can attach it later.
The technique is from Chuck Pasarro's yt video 'planking the Winchelsea'.
