Umbau der Proxxon FET
How much would one of those cost? I am not satisfied with the my standard FET. Does it work with that model? Rich (PT-2)
see post #13 or #14
Ein Umbausatz incl. einem Einlageblech kostet 340.-€ Ein Sägeblatt 25.- €
A conversion kit including an insert plate costs € 340. A saw blade € 25
@Rablok
But as mentione before - one set is reserved for me when we meet in March
see post #13 or #14
@Rablok
Is there any estimate on shipping to Eugene, Oregon, 97401 USA
REVIEW Conversion kit for Proxxon FET:
This afternoon I finally had time to mount the conversion kit on the Proxxon FET.
Got some support from Karl via email.
The cams of the old adjustment were ground, 4 M4 holes drilled, with this as a result:
When the knob A is loosened, you can adjust the guide bar over the round bar over greater distances. When you are near where you want to be, you tighten A. With the fine adjustment knob B, the guide bar has been turned against the saw blade:
Use the large black knob C to secure the guide bar to the saw table.
Set the digital meter to 0:
With the 2nd button from the left you switch between mm and inch.
A slat from the BN kit measured with the caliper:
4.23mm.
With the fine adjustment the guide bar turned to 4.23 mm:
And the slat fitted exactly between the saw blade and the guide bar:
Soon to actually use the FET.
And experiment with the digital meter. Because after a saw cut at a certain width, you can start again at 0 and continue measuring to the left or right.
Karl: Thanks for the support.
For the others: Is it worth the price? In any case, it will probably save a lot of fitting and measuring with the caliper. Now in the "Toys for Boys" category.
vorrei acquistare completo set per fet sega proxxon digitale quando costa e compro subito con bonifico bancario urgente
I would like to buy the complete set for proxxon digital saw fet when it costs and I buy immediately with an urgent bank transfer
Sorry to inform you, but Karl passed away appr. 1 year ago
Thanks, Uwe. Then I am sorry to ........ I missed that announcement.
Ho un Umbausatz per il Proxxon FET entwickelt.
Er verfügt über eine Digitalanzeige e erreicht eine Parallelität und Wiederholgenauigkeit von +- 0,03 mm Er kann mit 4 Schrauben vorhanden Tisch befestigt werden.
Ho sviluppato un kit di conversione per il Proxxon FET.
ha un display digitale e raggiunge un parallelismo e una precisione di ripetizione di + - 0,03 mm. Può essere fissato al tavolo con 4 viti.
View attachment 268516View attachment 268517View attachment 268518View attachment 268519
Buonasera, ho visto questa discussione e sono interessato all'acquisto della modifica per la mia proxxon fet. C'è la possibilità di poter acquistare? Grazie a chi potrebbe fornirmi informazioni.
