Good afternoon. I decided not to include sails on my Victory (well kit did not include these so will stick with this) however I will include some of the running rigging for the sails. My standing rigging will be black and running rigging the beige(tan....who knows) color of the kit thread. The kit rigging plans are rather sad and many additional lines and rigging details will be added to get something more authentic.It was Rather enjoyable doing some reading and researching while on holiday.
This morning I made More details and started some rigging for my lower mizzen mast. I made these parts not included in kit and rigging plan which are Circled in red.
I have added a bolster with 2 grooves in to my cap. Used a 6mm dowel cut in half and a saw to cut the grooves. The grooves are to support the top blocks and a sling for the stay which will be added later.
I used 2x2 birch and some needle files to make the lashing supports for the main blocks of the yard and 0.5mm thread for the lashing. The lashing line had to be rigged in an up and under pattern through the support.
A 3x1.5mm walnut wood was sanded And shaped for the vertical battens. These prevent the rubbing of the shroud lines against the square part of the mast and cap supports.
I seized the blocks to the lashing with 0.25mm thread.
