Good morning
The upper mizzen mast was looked at. Per instructions you merely insert the 6mm dowel cut to 215mm and taper down to 4mm.
At time I have used a scratch build Victory by EdT as a reference and this is what it should be closer to.
The difficulty is I can’t shape a 6mm dowel into octagons as it will be too thin and as I know I can’t use a larger dowel provided as I will run out.
I took some left over wood strips glued them together to make a square, planked with left over 6mm planks and then using an exacto blade and carved a sort of, close to, irregular octogon
. I cut the dowel shorter so the mast will be in two pieces. Drilled a center hole in the dowel And the octogon inserted a wooden support column for strength. Made the square block at base- made this too short and had to add some small adjustments. Can be seen in below photo.
Will need to to more shaping, clean up, and some wood filler will be needed on block at base. Sand. I think this will look better
Cheers
Grant
View attachment 290713View attachment 290712
