Bluenose by Liebre [COMPLETED BUILD]
More deck beams
Deck beams placed dryfit to determine the exact position of the mast foot
The mast made to measure, including the passage of the ring that is now loose on it
The mast is also dryfit in, and can now be mounted in it on an easier way and can be fixed later
The mast foot is glued
Good to know that a deck beam and 2 planks from the package are exactly the size between the rafters
More deck beams
Saw the current status of your build real life this morning. Very good looking.
Since I'm still ways behind you (and Peter, of course) I'll keep a very keen eye on your blog.
Johan
Thanks Johan , Peter and Dean
@Dean , it will take a while before she is loose
I am not going to follow the instructions and am going to make the deck on a variant of Peter, I also want to align the deck with the scuppers
Deck slats with Ecoline etc
What a beautiful model you have built so far Henk - and to think that you doubted yourself. With each step successfully completed, confidence levels increase exponentially so you will just get more and more confident giving her your own bent as time progresses. Well done!
Thank you Heinrich
Yes it is getting better and better, and can now see it a bit better and my confidence has grown
A lot of fitting and measuring, and very patient filing
The two little boys (P18 of the drawing) which took a lot of time to get them to fit I am very satisfied with them, they are now flush with the decking
