- Jan 21, 2022
Hello everyone. As I said in introduction I've started this model in august 2021 so this will be quite long post. Hope you can withstand.
I based my painting on model in Paris Museum. Painting in some places is a little bit off but at this point I can't fix it, because I wold trap myself in endless loop of fixing one part and braking other. Rigging is based on mamoli kit and there are also parts which are made of wood and brass.
This is stage for today . Standing rigging and shrouds completed -exept backstays.
Duble and triple blocks are 3mm from Falconet . Single are 2 and 3mm from amati
Beginning
1. Setting dead eyes and modyfing hull.
At red dots are places where I drilled holes or added brass eyelets.
Eyelet on deadeyes are made of solder brass
Deadayes 3mm and 2 mm
End result
Clamps are made of 0,25mm Amati rope and some little nail 1mm or maybe smaller
The direction of clamps should be in one way and they should be made of two nails so this is wrong, but at that point I thought heller holes would be ok
Beginning
End result
