Hello Friends,
Having temporarily set aside the installation of backstays, rigging work continued on the ties and halyards.
But first, I was asked via PM to provide a bit more detail on what I have been calling top ropes. As I understand it, these ropes were used to raise the upper mast segments. I chose to rig them as entirely removable once the topmast (or topgallant) was raised, and as a fairly simple affair (my research uncovered all kinds of increasingly complicated configurations...).
Two eyebolts are attached to the underside of the mast cap. I added a hook to the end of the rope - ran the rope down and through a sheave at the foot of the mast - back up through a block on the other side - and then down to the deck. Here are a few images:
On the foremast the top rope runs through the knighthead at the base of the mast and then would have been run to the capstan on the weather deck (and in my interpretation taken down after the mast was hauled into position). On the main mast the top rope passed through the weather deck to a lower deck where it would also have been run to a capstan. I'll show some of that in a moment.
On the mizzen, since the topmast is lighter, I simply rigged a tackle to an eyebolt on the deck at the foot of the mast. I have also seen this rigged to an eyebolt mounted on the mast itself (as well as to a cleat on the mast). The mizzenmast of the Vasa was never recovered so it's all just conjecture.
Here is the working end of the mizzen top rope:
Now on to ties and halyards. First of all, I should have rigged these before I did shrouds. Access was quite limited making what should have been an easy task very challenging (no yards have been attached - this is just roughed in at this point).
Here is the overall view at the foremast:
And now a few images of how I did the halyard at the foremast:
In the image above, the four sheaved knighthead should actually have a carved head on it like the others. Sadly, the head that belongs here disappeared in my garage months and months ago when I was cutting it off the unusable casting that came with the kit...
The line running through the fourth sheave (on the far right) is the top rope. It would have run to the capstan, but I just left it laying there.
And now at the main:
Notice how the stay has been offset on the mast - this is actually correct, not sloppy work on my part. You can see how the halyards simply pass through an opening in the deck. The seventh rope is the top rope.
And finally, here are a few images of what is happening up top with the ties (tyes?)...
Thank you very much for stopping by! I'm so happy I found this forum and all of you. This would be lonely business without a few folks walking alongside me...
