Okie Dokie, back to square one. I added the next set of 1.5 X 6mm planks working my way up the hull. But the more I looked at the Port or Starboard side the fit just was not right.
Back to where I started at the beginning of the week, these planks will also come off, mainly because of the humidity problems noted earlier. A close look at the lay of the initial plank (1.5 X 4.0 mm) on the Port side, shows that there are four frames that the glue bond has separated between the frame and the Bulkhead. In order to get a good foundation for the planks my best bet is a major do over. ( Ron can overnight the coins)
. Cheers Grant
