Most cables and ropes are laid in the direction shown in the pictures above. However, rope or cable can be made in right or left lay. Consult RC Robinson or other book on rigging to learn which lay of rope or cable was used on shrouds and stays. The convention is different at different times and for different ships, and the information we have on which lay goes where and when is very spotty.So the lay has more to do with the size of the rope/cable? I was thinking that they used right hand for the starboard stays and left for the port or some such thing?
in the topic below is everything explained why right-hand rope, when left-hand cable is used, why rope made of hennep is right-hand. And how to make ropeWhy are ropes twisted sometimes to the left and sometimes to the right? Are they used for different purposes?
I find it interesting to learn more about rope. Maybe lilla be tempted to make mycket own.in the topic below is everything explained why right-hand rope, when left-hand cable is used, why rope made of hennep is right-hand. And how to make rope
Make your rope on a rope walk
I did a lot of research on how to make rope on a rope walk and build my own rope walk. I love to share my experience with you. The quality of the rope delivered in your kit is not always of high quality. Fluffy, badly made so that you can better use it to tie up your old paper than to rig your...shipsofscale.com
cables and mooring lines: cable-laid from nine strands, left hand
Thanks Fred for the confirming commentDirk's (Dubz) article is a good summary of material relating mostly to the 18th century and later, and does a great job of dispelling the myth of left-hand laid rope in common use.
also from my side many thanks to Fred for these additional information.Dirk's (Dubz) article is a good summary of material relating mostly to the 18th century and later, and does a great job of dispelling the myth of left-hand laid rope in common use.
I can add from my background in maritime archaeology that I have never seen left-hand laid rope on a shipwreck, but all of the cable I have seen is left-hand laid. We are right now in the process of publishing a major book on all of the rigging finrs from Vasa (sank 1628), which includes over 500 yards of cordage of all types, from spunyarn up to anchor cable. A brief summary of how the Swedish navy rigged their ships based on this is the follows:
Shrouds: a mixture of three-stranded and four-stranded rope, right hand (four strand with a heart), no worming or serving
Lanyards: three strands, right hand
Running rigging: mostly three strands, right hand, but lower halliard ties and topsail sheets are four strands with a heart, right hand
Gun breechings: four strands with heart, right hand, served (some are reused old rope, possibly old shrouds, most are new)
Gun tackles: three strands, right hand.
An important point is that in the making of rope, each stage of the process twists the material in the opposite direction of the previous stage. Almost all yarn for rope is spun from the raw fibre as right-hand twist (Z twist), both in the ancient world, when yarn was spun by hand, and after mechanical spinning wheels were introduced. This is different from how yarn or thread for making cloth is made, where both left and right twist can be used, and many fabrics are made with the warp twisted one way and the weft threads the other.
After spinning of the yarn, the yarns are laid into strands (left-hand), and the strands are closed into a rope (right-hand). A cable adds a further stage, laying three ropes together left-handed. The reversing of the twist is necessary to balance the stresses in the rope so that it will hold together in use. If properly laid, so that all the twists are balanced, the rope is said to be dead, and will not twist or kink when loaded.
Fred
