I want to use my small lathe to tapper my mast and yards on my Le Soleil Royal which are quite long!! but when I attach the dowels have a shimmy when turning any ideas on how to resolve so a lathe can be used
It is a Chinese brandWhat make of lathe is it and does it have a tool post or are you hand turning ,
best regards John ,
that is what I was trying to do ,sand the taperYou need dowels big enough to turn down the wobble, and unless you have a tapering attachment it's best to sand the taper on the lathe.
Thanks for the info! Will Play around a bit to see what works best but what you have suggested will help especially the true center not easy on a 9mm dowel but that is the miniature world of modelling!Hi Bandido!
Like our colleagues I also tapered my masts and yards using sandpaper. I used two sanding blocks holding one on each side of the wood. This sanding generates lots of heat and the blocks protected my fingers/hands! I got rid of the wobble by 1: making sure I was in the true center on each end, and 2: using the lightest possible mounting pressure side to side. If I pushed in too firmly it caused the piece to bend and wobble.
Hope this helps a bit.
Hi Bandido!
Thanks for the info I will play around a little with some old dowels I have laying around to get some practice on the lathe!!Hi Bandido
The proposal of OldMan258 doing the tapering with sanding is the less complicated and in my opinion the best way unless you build a model in 1:10 or 1:5 scale. Using 3 to 7 cm broad cut sandpaper ribbons(starting with coarse to fine grades) and holding and squezing it gently around along the rotating mast and moving to the ends to be tapered .Slighly holding and pressing the sandpaper along the mast you can also control the shimmy dancing of the mast piece.
I use in the attachment shown primitive assembly system for tapering with good results.
You should just imagine that mast wood piece is a wild horse , which you have to tame it using sandpaper ribbons.
Kind Regards
I know the lathe vs. drill issue divides the room, but I've always found Jeff's drill technique superior to using a lathe. With longer spars it is more challenging because of the potential for wobble but if you go slow it works fine. Use a variable speed drill and go slow and use increasingly fine grit sandpaper.I user a drill with the dowel placed in the chuck. Some masking tape can be used to protect the end of the dowel from the clamp, but I prefer to have an extra 1/2" (12mm) of length to the dowel and not use tape. I put on a heavy leather glove on my sanding hand (heat protection) and hold a square of sandpaper folded into a strip. Turn on the drill and begin tapering the dowel with regular checks on thickness at various places on the mast-to-be. My sanding technique is to start at the unclamped/small end of the mast and sand toward the base about 2 inches. Then back to the end of dowel. On the next pass, pull the sandpaper back 4 inches and return it to the end. Continue this until you get to the base and then reverse the process. This method results in a fairly consistent taper. You have to stop occasionally to knock the sanding dust out of the sandpaper to get it to work well.
I think I figured a way to remove the wobble of the dowels used a water line gauge I had sitting around to hold the piece works great!!well I will be using my small lathe and the dowels do wobble due to the speed of the lathe 880 rpm the rest idea is interesting!! but thanks to all for your input this site is just GREAT!!
Here's how I do the tapering for spars/yards. I have a small "eBay" beading lathe (~$35) that I use for this task, but I remove the pointed end stock from the bearing. This will be my support for at the middle of the yard. I mark the mid-point, the points where tapering ends, where the yard is cut further in at the ends (if necessary), and the ending points for each end of the yard. I put some tape around the mid-point to a thickness that it is snug in the bearing (you need to push it into the bearing. One end of the spar is tightened into the drill chuck. I worked up a couple of pictures to help show the setup. The dowel was just a scrap piece and does not represent a real spar I was working on.I user a drill with the dowel placed in the chuck. Some masking tape can be used to protect the end of the dowel from the clamp, but I prefer to have an extra 1/2" (12mm) of length to the dowel and not use tape. I put on a heavy leather glove on my sanding hand (heat protection) and hold a square of sandpaper folded into a strip. Turn on the drill and begin tapering the dowel with regular checks on thickness at various places on the mast-to-be. My sanding technique is to start at the unclamped/small end of the mast and sand toward the base about 2 inches. Then back to the end of dowel. On the next pass, pull the sandpaper back 4 inches and return it to the end. Continue this until you get to the base and then reverse the process. This method results in a fairly consistent taper. You have to stop occasionally to knock the sanding dust out of the sandpaper to get it to work well.
