Model VICTORY by Deagostini, scale 1/84 [COMPLETED BUILD]
He also made the fore mast bits. I also made cuts for pulleys on a milling machine. that bit, on which there are 4 pulleys, the distance between the pulleys is 0.65 mm, the pulley itself is 0.8 mm wide.
I pre-installed the front bit on the deck, under the second one I still need to make cuts in the deck, so in the photo it still lies in the background
Sasha, super example of precision work where woodworking meets metal work and comes together as a working mechanical element on a mode. really well done!
Hi all. I have the next alterations at the shipyard. I did not like the "wells" for the kernels that the magazine offers and which I made. so I had to correct it again according to the original:):):)
It was done like this
And now it will be like this
Seats for the cores made on a milling machine
View attachment 320644View attachment 320645View attachment 320646
Hello Sasha. That is brilliant. I never understood why Deagostini made the wells that way. Cheers Grant
View attachment 320654View attachment 320655View attachment 320656
Yep- you owned that Sasha. Did you machine your sheaves? It is incredible to get 3 into that small space- well done. Respect. Cheers Grant
Hi all. Thanks for the kind comments and likes. And to those who just looked, also thanks. I have finished laying the quarterdeck deck. I sanded it down a bit. This is how it started...
And this is after the full laying of the flooring20220805_211318.jpg20220805_211329.jpg
Good afternoon everyone. Thanks for the comments and likes. I haven't posted anything for a long time, but I'm working with small elements and the progress is not very noticeable. Started trimming the bulwarks from the inside. I made 3 gun ports on the quarterdeck.
