Bluenose #54
  • Thread starter Thread starter Jimbo
  • Watchers Watchers 2
Hi, I am just about to make a start on building and, I already have a question.
The frame, I was going to use a Melamine Shelf from B&Q, I have checked and its flat and square, do I have to clear out the inside to allow the frames to sit in properly, or should I reverse the frame so it's up off the base. ? Hope I have explained that OK??
Hi Jim. I would advise starting a build log and then post pictures with your question. That would make it a lot easier to give you advice.
Thank you, I will start a build log today
You have already started one Jim. On sept 17th:
We are ready to answer!
