I am in need of an 8" Variable Speed Bench Grinder. Of all the research I have done, most of what I read is that it is sort of "luck of the draw" (from any brand) that does not have bad vibrations due to the grinder wheels being mounted off-center slightly. The wobble can be side-to-side or concentric problems.
I have also watched a few videos of this wobble fixed, but I really do not want to go through all that much trouble. I understand a little vibration goes with the unit as it is spinning at a very high rate.
Some of the fixes ( and even noted by Rikon - according to one user) is to rotate the large washer a little at a time until vibrations are minimized.
Another fix is to take a dressing wheel or a fixed dressing tool and hold it up to the wheel as you have the unit on and slightly press in as what this does, is it will "dress" the grinding wheel until it runs concentrically. (which I did not think of doing).
Now, with all that being said, does anyone here have any experience with your Grinder and can suggest one that you think is the best in your opinion as far as an "out of the box" experience?
Thanks
Thanks
