More to come
...We start your building log with the birthday wishes ....More to come
Well-ll, doan be discounting your own log of that Swedish ship, I pored over that one last evening. The ship is not in my sphere of interest but your work is worthy of study and as a technical document the log itself stands out.Best build log on the forum...
depending on the scale you are using and individual piece you may not notice a big enough difference to matter... it really adds up in the larger scales and across the long dimensions and whole sheet scans. My guess is that if you did each frame individually as you say then you are probably pretty good. Better than if you had done the whole sheet.Very true. A half mm here and there adds up to a big error down the line. I copied my frames one by one here on the copier we have. I’m going to check the measurements against the plan and see how close I am.
Ciao Tony, come hai fotocopiato, secondo me, c'è poco margine di errore con la giusta percentuale.Verissimo. Mezzo mm qua e là si aggiunge a un grosso errore lungo la linea. Ho copiato i miei fotogrammi uno per uno qui sulla fotocopiatrice che abbiamo. Controllerò le misure rispetto al piano e vedrò quanto sono vicino.
you could also use the scanner of the printer to testin case you are wondering what I am using for these comparo pix, it is an LED lightpad that I picked up on Amazon last year for about $60 USD.... you can dim or dial up the light... and it is crazy how bright this thing gets. the lightpad is A2 sized, and the effective light area (not counting borders is 41.4 x 59.5 cm or roughlye 24 x 18 inches. it comes with a few weak magnets that are pretty useless but a small stack of rare earth magnets will keep everything down well enough. if you plan on doing any tracing (and I usually trace out my pieces instead of using photcopies, this thing is a must. They come in all kinds of sizes if you dont need one this big. https://www.amazon.com/gp/product/B0829ZCWT2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
the pix below are at 0, 50, and 100% brightness... hard to tell the diff in the pix because the camera self adjust (but you can kind atell by looking athe measuremnet numbers on left side, buy trust me, at full this thing is blinding.
light at 0%
light at 50%...
light at 100%
sorry I was not clear, the light of the scanner (of your printer) to trace the imageYes, but as I said before the scan only option is even more expensive than a print - it makes no sense whatsoever to me but a print on paper is $7, a scan to to pdf is $11... WTF?
