Very enviable every day can see the ship, I very want to go to Portsmouth我大部分时间在上班的路上经过这艘船,我不知道有战士的套件,所以我会感兴趣地关注你的构建。如果您感到无聊或需要休息,请查看朴茨茅斯港实时网络摄像头,它实际上安装在 Warrior 的桅杆上
Another project I will send a later in the specialized production我很高兴看到你的新项目——另外还有一个非常有趣的项目
我会非常感兴趣
Does I understand it correctly:I can make your own gun deck, and artillery base, let a person feel gratified that may suite designers have given this situation, there is no one the muzzle is set on the frame, so it can be easier to finish the work
ONE question? How old is this KIT? Years ago- when I started .you bought the kit but all fittings were apart. had to be bought separatelyDoes I understand it correctly:
In the kit are no guns or muzzles included?
OK, the lids on the main gundeck can be closed
but the Warrior had (and has) also on the free decks some "normal" guns
and at the bow the big 110 pdrs
These visible guns should be there ........
this ship I do not know this this, but it looks very much like the Danish warship -with an engine too -JUTLAND,. Today a museum ship in Aebeltoft -Denmark. As far I remember it had (has) only one chimney. It was in the product range of Billing, but out of sales for the moment.ONE question? How old is this KIT? Years ago- when I started .you bought the kit but all fittings were apart. had to be bought separately
The Jylland was a much smaller wooden steam fregatte compared to the iron hull Warrior.this ship I do not know this this, but it looks very much like the Danish warship -with an engine too -JUTLAND,. Today a museum ship in Aebeltoft -Denmark. As far I remember it had (has) only one chimney. It was in the product range of Billing, but out of sales for the moment.
Thanks, Uwe, as I do not know anything about Warrier. what could my attention is that both ships apart from the sail had an engine board? to restore Julland ha taken a lot of years, mainly a lake of money, but not a model of my interest. when I entered the Navy in 1965 she was in the port of Copenhagen used as a sleeping quarter, mostly for U-Boats crew.I found the page from Model Expo offering the Warrior showing guns as part of the kit
View attachment 345756 View attachment 345757
If they are missing ion your kit you should get into conatct with Billing Boats
Thank you for your remind may be translation problems my original intention is not main deck gun in the suite, not even the main deck. I can't accept closed doors, so to oneself我理解正确吗:
套件中不包括枪支或枪口吗?
好的,主甲板上的盖子可以关上
但是勇士在自由甲板上也有(并且有)一些“普通”枪支
在船头是大 110 pdrs
这些可见的枪应该在那里......
