Coming along nicely now, soon be cutting off the jig. However, and there is always a 'however', problems in Transom area, my fault, but a point to note for anyone not at this stage yet.
After fitting the rear deck, I was left with a bigger gap at the back than I should have, after investigation I found that the last couple of beams were very slightly high, and with the slope of the transom, it doesn't take much to exaggerate this gap, so, my remedy, and this is only mine, was to unglue the last beam, which also at this stage meant ungluing the deck and the blocks, then trim down the beam underneath, shown by the red arrows, and reinstall, now the gap has certainly closed somewhat, so I'll let you know next time if everything else fits.
