I hve a USS Confederacy kit I want to start. The bulkhead former parts(2) are slightly warped. What's the best way to straighten them?
I had that thought but wanted to check with more expoerienced modelers. I'll use warm water, immetrse the parts, count to ten, remove tgen press under weights overnight. Maybe that would help. I really do not want to bother Model Shipways about this until I try this.You could soak the parts in water, then put them under a heavy weight to straighten them out.
I had several long deck pieces on my sternwheeler that were warped. I filled an old Windex spray bottle with hot water, liberally sprayed the pieces and placed them between two old 24 inch book shelves. I used a dozen books for weights and left the setup overnight.I had that thought but wanted to check with more expoerienced modelers. I'll use warm water, immetrse the parts, count to ten, remove tgen press under weights overnight. Maybe that would help. I really do not want to bother Model Shipways about this until I try this.
Warm water bath and press firmly between books. I havd about 500 or so in my library.I had several long deck pieces on my sternwheeler that were warped. I filled an old Windex spray bottle with hot water, liberally sprayed the pieces and placed them between two old 24 inch book shelves. I used a dozen books for weights and left the setup overnight.
I have a warp in the wheelhouse deck of my Billings Boat St. Roch but I'm hoping that 2 part epoxy and some clamping will overcome the pressures of the warp as the whole structure is built and ready to install. I tried the hot water and weights method to no avail.I hve a USS Confederacy kit I want to start. The bulkhead former parts(2) are slightly warped. What's the best way to straighten them?
I also tried hot water and weights, It didn't work. I sent a request to Model Shipwayts explaining my problem and noting the warpd woog was a reddish color not like the other wood. When I buy a kit I allow it to 'rest' at least a month si it is acclimated to my house. Don't know if that has any effect.I have a warp in the wheelhouse deck of my Billings Boat St. Roch but I'm hoping that 2 part epoxy and some clamping will overcome the pressures of the warp as the whole structure is built and ready to install. I tried the hot water and weights method to no avail.
After ywo attempts at warm water soak and weights I sent a request for replacement parts to Mocdel Shipways explaining my problem and noting the warped part was reddish in color and not like theother parts. Wonder if the wood could be the problem.Oh ok, yes, the Bulkheads in this case is "plywood" and you are concerned that the "layers" will come separated. I think M.E. has a web page on their site that you can order replacement parts. They are good about doing that.
I think Ply is a little more tricky to bend, as it is not a solid wood. However, it can be done. Instead of just pressing flat, I have run very hot water over the part and then placed the part in a "counter" or opposite bend and let it dry that way, then when it flexes back, it sometimes will flex back to its desired shape. The counter bend does not have to be that much. It can be anything.
f.e. take a small stick that is maybe 1/8 inch square by about 8 inches long and while the ply is wet, lay that Bulkhead on top of the stick and put a weight on EACH side of the Bulkhead as to cause the BH to bend (of course in the opposite direction). Let it set for a little while and even BEFORE it dries release the tension and see if it is straight. If not put back on stick again. It might take a few times to doing this.
Then again - you can do this maybe while waiting for your new parts. Just an idea for you to try. Also, if you are impatient like I can be, take a hairdryer to it when its wet -![]()
I do not know if it makes any difference but here's what I think.I'm no wood expert. Wood accepts/loses moisture. This can influence shape. Florida is not Minnesota. I keep the house about 40% because of my arthritis. Maybe its a psychological thing for me.Interesting. I have never heard of letting a kit acclimating like that.
