I would use treenails for the keel and stem parts and also for the frames. For a sloop 6 nails are common for the keel parts. David shows the position for the treenails at the frames in his book. There is one bolt in the centerline which goes through the keelson to the frames. Further you can show 8 treenails at the side for the connection of the keelson parts.Good thoughts Christian. Unless I read wrong, bolts were common on the centerline framing and then treenails in the frames?
Time for some CNC-equipment?The top to bottom taper should be more concave
This part looks very nice and sharp, Paul. Well done.This piece (stern deadwood) was almost the end of me: tapered top to bottom and also front to back - and then notched to receive the aft cant frames. But the kit design made this something even a relative newcomer could accomplish with careful chisel work and sanding blocks. Well done, LSS and Mr. Hunt.
The top to bottom taper should be more concave but I'm hoping this will still work. Thanks for stopping by!
Good morning Paul. Your work is soooo good.! I see what you mean re the tapering. I think the fact this is macro the convex may be exagerated.You are talking minute margins for sure. Unfortunally when you build a POF ship minute margins make a difference so I hope this works for you. Now you know why Im still on POB kitsThis piece (stern deadwood) was almost the end of me: tapered top to bottom and also front to back - and then notched to receive the aft cant frames. But the kit design made this something even a relative newcomer could accomplish with careful chisel work and sanding blocks. Well done, LSS and Mr. Hunt.
. Cheers Grant
I understand exactly where you are coming from. I grew up in the metric era and inches to me are a proper PITA. Your work though looks beautiful, Paul. Just take your time, check and re-check; then we can't be too dumb,Thank you kindly, gentlemen, for the encouraging posts and likes. I've decided to refine the tapering a bit more in order to get me closer to the build requirements found in TFFM.
A passing observation from my experience using this series of books thus far: the measurements provided in the text are generally given full-size and in the imperial system. For example, for the stern deadwood I am told to make the width at the bearding line (basically where you see the notched area for the frames to seat into) 15 inches and then taper down to 5 inches at the bottom where the deadwood joins the keel.
By using actual measurements from a full-sized ship this allows the book series to accommodate every modeler's preferred scale. Makes perfect sense, right?
Well, this creates all sorts of tripping-up points for me because I think in metric (Why, you ask? Because I can picture 2.6 mm in my mind but not .104 inches). This means I need to first convert inches into mm and then adjust for my scale (1:48). Of course, the math isn't hard, but it all introduces room for mistakes to be made. I find myself constantly checking and recalculating things over and over again. I can't tell you how many times I've said to myself: how can you be so dumb?
When my dad was frustrated with me he used to say, "you've the dumbest smart kid I ever met." I didn't like that very much - but it seems he may have been right.
I am a big fan of your work - and maybe get a big fan also for this kit
That was also my thought by the last picture.Are you modeling now on a computer and make a virtuel model?
It is not a real photo of your wooden model stern post, or?
