Russian "Four-oared Yawl" | Scale 1:24 | Falkonet
To build complex things like the Polotsk is not possible at the moment, there is just not enough time. But I needed something between my fingers, a small project which is feasible while our little daughter is still ... very small.
Generally I like small boats very much and therefore I decided for a Russian "Four-oared Yawl" in scale 1:24 from Falkonet.
In itself a nice kit with a but unfortunately partly widespread problem. It is lasered idealized, i.e. it is not taken into account that 2 x 0.05 mm laser burn marks are removed from each plank, I like to do this very thoroughly, which then unfortunately accumulates to over 1.0 mm. Annoying if you then have to widen one or more planks. But I think the fewest will notice. At the stern, I can say right away I should have let the widening be, but even that I get probably "workarounded" :-D
The frames I have made from 1.0 x 1.0 mm sawn pear strips, I did not wanted to clean and glue the provided 2 x 0.5 mm lasered strips :-)
History reference
In the 19th century, the English shipbuilder Veniamin Fomich Stoke built more than 600 ships of various ranks in the service of the Russian Empire, including the famous frigate Pallada. The archives contain many drawings of boats of his authorship, among which the yawls deserve special attention, as the most massive and simple of all types of small vessels. Usually they had clinker sheathing, one mast and 2 to 8 oars. Most of the ships of that time were armed with yalami in order to perform tasks of a different spectrum: reconnaissance, supply and transportation of the crew. They found no less widespread use as a pleasure craft or port boat.
Our yawl was reconstructed according to an archival drawing from the funds of the RGAVMF, its forms are closest to modern models, but at the same time, it has a characteristic feature - these are teardrop-shaped contours that add beauty to its outlines. This prefabricated model is an excellent tutorial for beginner modellers on the device and the general appearance of the boat.
cheers
Dirk
Jim is correct - very accurate, but this we already know from you - I do not expect something else.
I like also the overall appearance of the boat - very realisitic in addition with a nice colour and also small fine grain which is fitting to the scale of 1:24.
One question: The small gratings - are these one single part which was lasered? Looking very good
Nice case with a good contrast of the grey coloured bottom.
I forgot to ask you about the small pinky tool you showed in one or two photos.
Is it a heating iron for bending planks? How is your expereince with this tool?
and: Is it also available in different colours? ;) definitely you will find it fast on a crowdy working table
And we continue with the "interior" :-)
Btw, the very nice supports turned from pear are part of the kit :-)
The brass parts were blackened with the brass stain from Dräger. Use a sanding pad to make the brass bright, then 10 seconds in the stain and you're done :-)
Again, a little improvisation was necessary because of the precision of the laser work, which does not always work in reality. The seats could have been 2 mm wider :-D
The mast securing looks good and works by the way, even if I think the belaying pins could have been a bit bigger.
Here, all the etched nail holes have been drilled out and replaced with miniature rivets. I like this, if slightly "exaggerated", impression.
cheers
Dirk
And we continue with the "interior" :)
Btw, the very nice supports turned from pear are part of the kit :)
The brass parts were blackened with the brass stain from Dräger. Use a sanding pad to make the brass bright, then 10 seconds in the stain and you're done :)
cheers
Dirk
Perfect
How do you like the kit? Built this one myself along with few other kits from Falkonet and think they are the best out there, besides perhaps Marten and Howes. Their RND comes from a true rivet counter.
