The 4 Railroads Project. (4-Bahnen Projekt)
Indeed there is a lot of wiring regardless of scale. With my large scale layout I have most my wiring terminated at the rear of the layout. For convenience I use Peg board (no holes to drill) for my wiring backboards. I’ve attached a couple photos.
The above photo shows the major voltage feeds. The photo below is a large diode matrix that controls switch, signal, uncoupler motors and voltage to many LED’s.
The photo below shows the wiring of my master control panel.
All my wiring is color coded and backed up by a multipage spreadsheet. On the many occasions that Mr. Murphy and his pals the Gremlins have shown up, it’s been pretty easy to troubleshoot wiring problems.
@pianoforte , sorry I don’t mean to bugger up your log. Kurt got me thinking about all the colored wires that most visitors won’t see.
Simply Incredible job keeping everything organized.
Thank you for the likes. Befor ballasting the tracks and building the terrain, the pylons for the catenary still have to be manufactured and set. Since the catenary should look as realistic as possible, I decided a selfconstruction solution of the company Wenz from Germany.
First, the location of the poles and the overhead wire run must be determined in order to be able to determine the exact length of booms.
Gauge and thread are used to define the zigzag of overhead wire and thus the mast cantilevers.
I will choose the following 2 lengths.
to be continued.
