Kit Review Schooner for Port Jackson (1802) - 1:36 by Miniature Arts
Uwek
Administrator
Administrator
Forum Moderator
Vienna, Austria
Today I would like to show and describe you the content of a very interesting kit
in scale 1:36
by Miniature Arts
HISTORY and Plans for an Australian schooner of 1802 /1803
In 1785 the First Fleet arrived in the new British colony of Port Jackson (now Sydney Harbour) in New South Wales and Arthur Phillip was appointed as the first Governor.
In 1790 the governor of Australia asked the Admiralty in London for two vessels of 30 to 40 tons, which should be shipped there in frames, accompanied by some skilled shipwrights to build the ships. His request was partly fulfilled by sending materials of a schooner of 41 tons, that was put together in Sydney and served the colony from 1793 to 1805. In 1802 the Admiralty ordered the Navy Board to produce drawings of two ships according to the governor's specifications and sent a copy of them to Port Jackson (today known as Sydney Harbour). The original drafts of the schooner are still in the National Maritime Museum in Greenwich.
Meanwhile, the NSW Government had already built various other ships before 1803. In 1797 His Majesty’s Dockyard was opened at Port Jackson for building larger vessels.
It can't be ascertained whether actually a ship had been built to the plans at that time, but in 1807 a schooner of similar size named Mercury was launched in 1807 for the Sydney merchant Thomas Reiby. He was an influential trader and former ship's officer and one can assume that he got the plans and some support from the governor.
The Royal Navy’s 1803 design of a ‘Schooner for Port Jackson’ has been recognised on the obverse of Australia’s twenty dollar banknote since 1994. A sketch of the schooner is beside the portrait of Mrs Mary Reibey, who arrived as a convict and rose to become a respected and successful owner of a cargo shipping business. Her fleet included the Mercury, a schooner similar to the 1803 design for the Port Jackson schooner.
Although the 1803 plans for a ‘Schooner for Port Jackson’ are commonly believed to be used for the first ship built in Australia, no records have been found of any ships being built according to these plans. However, it can be claimed that the plans were the ‘first Royal Navy plans made for a ship for use at Port Jackson, and to be built at Port Jackson, in Australia’.
More details on history and the drawings of the schooner are given in the book by Karl Heinz Marquardt, The Global Schooner, Origins, Development, Design and Construction 1695 - 1845, Conway Maritime Press, London 2003, ISBN 0851779301.
Remark:
So a frame "kit" in 1:1 is basis for our kit in 1:36
and here the contemporary drawings available at the NMM, which were the basis for Marquardts work
Unnamed 53ft Schooner (1803)​
Scale: 1:48. A plan showing the body plan, modified sheer lines with some inboard detail, and modified longitudinal half-breadth proposed for an unnamed 53ft Schooner for the use in Port Jackson, Australia. This shows that the vessel was modified from a single-masted vessel to a Schooner. A copy with the modifications was sent to Chatham Dockyard on 3 January 1803 to be forwarded to Calcutta and then to Port Jackson.
Signed by John Henslow [Surveyors of the Navy, 1784-1806] and William Rule [Surveyor of the Navy 1793-1813].
Scale: 1:48. A plan showing the framing disposition, and the deck plan for an unnamed 53ft Schooner to be built at Port Jackson, Australia.
Scale: 1:6. A plan showing the middle and lower pintle and brace for an unnamed 53ft Schooner to be built at Port Jackson, Australia.
You can find these contemporary drawings here:
"Homecoming" - by K.H. Marquardt
Now let us take a look at the kit model
The model kit is available for very reasonable price either in Pear wood or also in Cherry wood and can be ordered viw Dry-Docks Models and Parts
Both versions are in scale 1:36
the finished model has a
Length of 71,5cm
Width
of 21,0 cm
and
Height of 53,5cm
The model is prepared as a Partial POF kit , means, that the midship section over the length of the main hatch is prepared as a Plank on Frame model.
The original framing is visible in one of the contemporary drawings in the post before.
The bow and stern part are conventional POB (Plank On Bulkhead)
The concept with mixed POF and POB will be clear looking at this model under construction - the framing and the deck structure with beams, carlings etc. is following the contemporary drawings - really a great idea to combine this. So a partly open and not full y planked hull with visible structure can produce a very attractive model ...... I love this idea
But now let us take a first look at the finished model
Kit Packaging
The kit comes in a sturdy cardboard box carefully packed in bubble wrap and taped for further security. Such packaging will ensure accidental drops and other unexpected damages as well as moisture while transportation.
(I opened the parcel already before I made the photo)
The Kit Content in Overview
The main wrapped package with the wooden sheets - the ruler in front is 50cm long
The Overview of the wooden parts (from left to right: Plawood of different thickness, templates, pearwood sheets, round material, red sandalwood )
The package included various sheets of high-grade plywood parts for temporary construction jig.
very accurate laser cut
The plywood sheets for the bulkheads and deck templates
Pearwood sheets.
The sheets range from 4mm thick to 1mm thick, high-grade timber precisely cut by Laser,
the hull planking
beautiful color with very fine grain
the frameing
accurate laser cut
The deck planking also in pearwood
detail of the deck planking with prepared correct treenail pattern - in scale 1:36 definitely in scale
two sheets made out of the expensive red sandalwood - close to black but with visible grain
Sorry for the photo quality, in reality this wood is looking very good - parts for decorative elements, wales and the railing - so no painting necessary
some more pearwood sheets with the beams, carlings, keelson etc.
and some sheets with the parts for the barrels and boxes - a nice add on to bring some "life" into the model when you display it with open hatch
In addition we have some round material in form of dowels for the masting etc.
also in good quality
Accessories
a small bag with brass rod and also some black fishing line
You will ask now - fishing line for what?
the treenailing pattern in the deck is laser cut through the wooden sheet - so with the fishing line the modeler can immitate the treenails (some modelers are making thme in this way - nice idea
alternative the holes can be also filled with some brown wood filler to immitate the treenails or even use my tooth-pick method
Defintely a good idea, so mistakes in drilling of the holes can be avoided
a bag with different rigging lines
in different sizes and colors
also in very good quality comparing to most other kits
several bags with very good quality blocks are included
I think here there will be no need to buy extra better blocks from the aftersales market - these blocks are really good
in the next post we will see, what is in this box
The kit sontents also a plastic box with further fittings
tiny bolts (no nails made on the lathe)
these are only 1cm long
one photo etched sheet for the rudder hinches and horse shoe
two well casted anchors
for the parrals
brass eyebolts and rings
some sheets of some elastic black material which is planned to immitate the caulking - let us see in future how this is working - but definitely the manufacturer is helping the modeler to execute the model with some special solutions
and one heavy bag
with stone material to make the balast in the hold of the model
Best quality material - the best stones and absolute in scale -> GREAT
Our Kit review journey has almost come to the end, the only part that is left is
Instruction Manual and plans
a ste of drawings in correct size in scale 1:36
and also a belaying plan
The drawings are showing everything what is necessary
The Manual is written in english
with a list of content
the main information are shown in 3D-sketches and english information (in the following some samples)
also included are here several pages showing every individual frame as a paper template for gluing the frame parts together
in addition the manual is including also tow of the laser cut sheets with the onesided adhesive tape for the planking caulking
the backside with the protection layer
this can be a very clever solution for immitation of caulking
With this, the Schooner for Port Jackson kit review comes to the end.
My observations while making this kit review
The kit is designed in a new way,
A combination with POF and POB will result in a very attractive model.
With scale 1:36 a very good size for beginners and also internediate modelers with thick fingers.
Maybe also very attractive for beginners with POF modeling, who wants to test this way of ship modeling.
Historical attractive especially for the australian friends.
The quality of wood (I have the pear wood version) is very good and the laser cut, but also all the other parts and fittings are of good quality.
Drawings are showing all necessary information and in combination with the english manual the modeler will be able to build the model without bigger problems.
Clever ideas with the treenailing pattern and the caulking material - the results are looking good.
And a very reasonable price for such a model.
In summary the kit is highly recommended
What I forgot: Sorry - but the model has no Guns
so everybody looking for a "war" ship - No the Port Jackson was a "working horse" - a very attractive one!
Her some more impressions of a finished model
and the model in another series of photos
I like the model very much ......
Hi @Uwek. I'm a little confused. Why have POF components that are covered with planking as shown on the completed model? Or is it just left to builder's choice... Sorry for my potentially ignorant question but I like the look of this little boat and might be interested one day...
Hi Paul ,for some reason the manufacturer’s protototype were completely coverd up with planking ,but it is your choice how you finish the model
Not Uwek however, with a little “Artistic license” one could leave the center deck open. Just my two centavos.
I’ve been looking for a “new” project for myself and might jump into this one myself.
No Guns, no decors :confused:
