     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Impressive video. With that in mind, milling small wooden details should be no problem.Cut the address and paste it into the search field on You Tube, I couldn't make the link, impressive video,
This tells me that it is possible to use coordinate tables together on this machine, Knut-
How does the drill chuck mount? Morse taper? If so, quality drill chucks can be purchased ie Jacobs. And as far wobble in the drill press quill is concerned, itmay be improved by replacing the bearings with quality sealed bearings available in the aftermarket. Working on models and the materials they have is no big load or issue with these machine tools.I hope this drill chuck tightens well enough, if not I'm considering switching to a keyed drill chuck.
As you say, the most important thing is to remove small amounts of material in each operation.
Some chucks mount via a morse taper tang into the quill, while others are removed by opening the jaws and removing a screw internally....and the are some OLD designs that actually are threaded. There are a lot of youtube videos on removing a drill press ( and even hand drills) chucks.....After I watched the video above, there was an advertisement for a video on changing the drill chuck, it looked like it wasn't that difficult.
Wondering if the man from China has changed the bearings and the drill chuck. hmm
Can you use a dial indicator to measure the run-out? Measuring the chuck and measuring the quill? If it wobbles, where is the errant motion coming from?It would have been interesting to hear what is said about the Scheppach drill press, it is not, Hobbling with the head, on my machine when it is stopped.
I will try with a thick drill and different speeds, then I can tell more.
