Like this:@Philski, how do I measure what you say, measure indicator, I don't have, I think, do you have any examples of how this is done,
I will do some experiments with a milling cutter, will show the results later, greetings Knut-
     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
There are such things known as a mill/drill. Having a dedicated mill just for modelling can be expensive....for modelling, a drill press may well fill the bill for such work.in my opinion. a drill press is a drill press, and a milling machine is a milling machine.
I have a full size drill press (Delta 17") but also have the Proxxon MF70 micro mill. I use both. A man cannot have too many tools!I have a dedicated mill and I use it to drill holes too with the proper bit. But I see your point.
Note the Dremel 'drill press' in Norway's photo. When you have little money and a big project you have to make do.Just found this photo published by our member @Norway in his log
The same drill with table(s)
NORWAY`S HMS BLANDFORD CROSS SECTION BUILD 1-32
Nice little progress, Knut. I like your dead eyes, they look great.shipsofscale.com
