In need of Help
Thank you for the help. Was there ever a standard length for individual hull planks on large warships?
There was no standard length.
The shipwrights used the available wood material, that means, that the length of a hill plank was defined how long the tree grow straigth.
Most ships were build out of oak trees, so the length of planks was limited.
Usually we say, that the planks were around 7 to 9 meter long, maybe 6 to 8 meter .....
The mentioned 20 feet length could be correct, which is appr. 6 meter
in scale 1:46 -> it would be 6,1 meter / 46 = 13,3 cm
Hi there,
I suggest you search through members build logs with those particular models and see if they are suitable for you.
