Whaler RAU IX 1 : 45 - Graupner [COMPLETED BUILD]
Hello today I would like to introduce you to my whaler RAU IX. I bought the easy started kit on ebay. That means the hull has been shaped, including the engine, frames and rudder. The deck is also almost finished and still needs to be glued in place. Everything else I need is included, including the fittings. Since I continued with the construction a while ago, I will describe the construction progress at the beginning and let you know when I have reached the current status.
20210602_194322.jpg20210602_193129.jpg20210602_193259.jpg20210602_193307.jpg20210602_193311.jpg20210665.jpg20210602_193356.jpg20210602_193529.jpg20210602_193725.jpg20210602_193730.jpg20210602_193940.jpg20210602_194028.jpg20210602_194506.jpg20210602_194858.jpg20210602_194944.jpg20210602_195415.jpg20220521_172900.jpg
Next up was the superstructure. The first side walls were glued and fixed. So that everything fits on the deck afterwards, I also adapted it directly to the deck. To prevent the superstructure and the deck from being glued together, I put cling film between the deck and the superstructure.20220724_180856 (1).jpg20220804_174855 (1).jpg20220804_174900 (1).jpg20220807_172806 (1).jpg20220807_172811 (1).jpg20220811_154552 (1).jpg20220828_170138 (1).jpg
The Rau from Graupner was one of my dreams when I was young, so I guess the kit is around 40 or 45 years old.
At this time I built together with my father the Bugsier and the Löschkreuzer Weser...... long time ago
Wish you success with thid kit - I am sure you will have it
Last but not least, the white stripe was missing. On top of that came a few more coats of matt clear coat. Then I treated myself to a brass screw, the red plastic screw didn't work at all.
Hello
Then I distributed a good 3 kg of small lead balls in the hull and put the Rau in the bathtub and trimmed the ship. Then I fixed the lead with epoxy resin. So that was the past, now back to the present. All I'm posting now is the current build status. It may also take a while until the next report comes, because it's summer now, we've got 30 degrees with sunshine right now and we have a house with a garden. So you always have something to do. Despite everything, I'll be back because I feel very comfortable in this forum, everyone is very nice and respectful. Thanks again.
20230410_164556.jpg20230410_164600.jpg20230307_102215.jpg20230307_102240.jpg20230307_102337.jpg
