Hello merci pour le conseil , c´est que je vais faire. La fixogum est le top .Super - you are making sawdust already - the parts for 4 frames are already cut out
Before you cut out more frames, I would try to install 2 or 3 frames together, so you recognoze, if you have to adjust the cutting out somehow - f.e. more or less meat etc.
How is Fixogum working for you? Short time ago we recommended it to @Ornholt for his Young America project
ça colle le papier sans le déformer ni le décolorer, comme Tobias l’a expliqué également et les bavures sur les autres papiers juste à côté ou sur le bois en frottant avec le doigt se transforme en boulette et laisse la surface nickel. je recommande également à 200%, merci beaucoup les amis pour cette astuce
Hello, thank you for the advice, that's what I'm going to do. The fixogum is the best.
it sticks the paper without deforming it or discoloring it, as Tobias also explained, and the smudges on the other papers right next to it or on the wood by rubbing with the finger turn into a ball and leave the surface nickel. I also recommend 200%, thank you very much friends for this tip
