Good afternoon Paul. Beautiful work.This week I turned my attention to the keelson. It is made of five segments along its length with each of the segments joined by a hooked scarf joint. At the bow of the ship the last portion of the keelson tapers from 12" wide to 9" wide and is then joined to the 9" wide stemson.
The kit design calls for a simplified keelson (and keel) that lack the notches on the facing segments commonly seen on other (more impressive) POF builds. I was happy to follow the simplified design as the notched faces are impossible to see on a completed model.
My very first hooked scarf joint in clamps:
Another one, but now sanded to the proper height of 13":
The upper edge of the keelson (and stemson) receives a bevel. I'm sure there is a way to make the bevel using a mill or a scraping tool. I just used files:
The bevels on the stemson (the notches are for breasthooks and deck hooks to be added later):
The top of the stemson must be placed precisely as it eventually establishes the vertical position of the upper deck (I used a gauge set to a measurement taken from the plans):
The keelson is bolted to the keel with 1.25" bolts (every other frame). I used copper wire and will postpone burnishing the ends until I see what happens to them naturally:
And the scarf joints also receive smaller bolts (0.75") at the ends of the joined timbers (lip bolts?):
I am more than a little annoyed that these are not round. All I can think of is that I compressed/distorted the copper wires while inserting them. I'm not sure how many more bolts will be used on this ship, but I need to solve this problem.
The overall view and a closer look of the installed keelson:
Speaking of problems...at the bow I always knew that I needed to refine the inner face of the hawse timbers to establish their proper thickness. I postponed that until seeing how they related to the stemson. Well, its worse than I could have ever imaged. Check this out:
The stemson should be proud of the hawse timbers by the thickness of the planks that will terminate into it (as you can see it is rather substantially submerged).
I need to think about how to solve this issue without damaging the stemson and still end up with a reasonably contoured (faired) inner face of the hawse timbers. I sure wish I knew what I was doing...
….and Paul makes this statement on only his 2nd ship…and a complicated POF build…I sure wish I knew what I was doing...
Paul, just thinking out loud, it appears to me sanding the haws timbers to match the stemson (as it is placed now) would throw the inner hull way out of plan shape. It looks like you have a hooked scarf right at the perfect location at the lower beginning of the haws timbers where you could map a new stemson based on the haws timber's location provided you have enough spare wood to do that.This week I turned my attention to the keelson. It is made of five segments along its length with each of the segments joined by a hooked scarf joint. At the bow of the ship the last portion of the keelson tapers from 12" wide to 9" wide and is then joined to the 9" wide stemson.
Paul, Don’t worry, it’ll turn out right, I’ve gone through my whole life saying to myself, “ I sure wish that I knew what I was doing “ and life has still turned out pretty good. KenThis week I turned my attention to the keelson. It is made of five segments along its length with each of the segments joined by a hooked scarf joint. At the bow of the ship the last portion of the keelson tapers from 12" wide to 9" wide and is then joined to the 9" wide stemson.
Hi Paul,This week I turned my attention to the keelson. It is made of five segments along its length with each of the segments joined by a hooked scarf joint. At the bow of the ship the last portion of the keelson tapers from 12" wide to 9" wide and is then joined to the 9" wide stemson.
Hi Paul, sorry I have never seen these joints, can you give me some hints? FrankThis week I turned my attention to the keelson. It is made of five segments along its length with each of the segments joined by a hooked scarf joint. At the bow of the ship the last portion of the keelson tapers from 12" wide to 9" wide and is then joined to the 9" wide stemson.
Hmm. You might be right about the amount of reshaping that is necessary. I may have to do both. The thing is---I don't really know how to figure out what the 'plan shape' is in that area. I have a cross section that shows the shape at the midline of the vessel (no problems there), but I don't really know how to interpret and apply the swoopy line drawings I purchased recently from Harold Hahn's son (his dad built the Kingfisher) which probably contain the information I need. But I DO know the anatomy of the stemson (definitively) so that needs to drive the ship (as it were) with regard to figuring out the correct solution.Paul, just thinking out loud, it appears to me sanding the haws timbers to match the stemson (as it is placed now) would throw the inner hull way out of plan shape. It looks like you have a hooked scarf right at the perfect location at the lower beginning of the haws timbers where you could map a new stemson based on the haws timber's location provided you have enough spare wood to do that.
David shows 4x but I have seen far more examples of scarf joints using 6x (than 4x). In other words, I suspect you are correct!Hi Paul
as far as I remember you need 6 small nails for the connection of the keelson parts. The joinery looks really good.
Thanks Maarten. I think a rounded head would have looked better than what I have done. Next time!Hi Paul,
Next time try to roll the copper wire with a blunt knife to create the bolts. You will then create a bollow head on it which will only flatten while you tap it into the hole. If you tap a flat surface the shape of the round copper will disform.
Regarding the hawser timber sanding I see this proxxon tool on your most wanted list.
But are you sure these are properly installed. It seems odd that so much should be removed in a specific place.
I always admire your tenacity in these situations. Barring any relevant research in this area, as a last resort you can always assume the hawse hull shape as correct as this design allows for and build the stemson out accordingly. I know this is no real help and I'm not really saying anything you don't already know. Again, just thinking out loud.I don't really know how to figure out what the 'plan shape' is in that area.
True story, as Grant would say. Despite the issues to be resolved, your work is incredibly precise Paul, and a pleasure to observe.You’ll figure it out, Paul. You always do.
At first my thought was: What a brave man. But no, you do was you have to do after considering your options. This seems to be the right way: little by little sanding and the Stemson will come in line.My thanks to everyone who offered encouraging words and suggestions for how I should address this little problem. I wish I could tell you that I allowed some time away from the model for careful formulation of a restorative plan. But it turns out I lack that level of personal maturity. For the record, this unwillingness (inability?) to allow problems the necessary resolution time got my keester in a ringer working on the hull of my Vasa so it would seem that I am untrainable in this regard.
I tried to locate line drawings that would provide some insight but all I could find was guidance regarding the outside of the hull. I then used some long-armed calipers to measure the thickness of the bollard and hawse timbers and realized just how thick I had left these in the lower half of the hull. I then pulled up my collection of Kingfisher build logs and became further convinced that the issue resided in the thickness (not the position) of the bollard and hawse timbers.
Some careful work with woodworking chisels and then a variety of sanding tools consumed the next two work sessions.
As a reminder, here is where I was on Friday:
After now just a few minutes ago:
Not perfect, but I think I'm back in the game... Sadly, I cannot be fully confident that my solution was the proper one. If it's not...well, let's hope I don't need to go there...
Thank you for your ongoing interest and involvement with this build report!
In Dutch we say: “Meter = weten!” / To measure is to know.I then used some long-armed calipers to measure the thickness of the bollard and hawse timbers and realized just how thick I had left these in the lower half of the hull.
