Unfortunately, I'm in no position to give you any usable feedback, other than that I find it an attractive addition.Before finition, it looks like shown about this fore-mast's picture, what do you think about this detail add-on ?
Through a fully enjoyable ride... congrats!Without the sunlight, I verify the look of future stays about main and fore mast, in order to avoid any surprise :
you are absolutely right with your question, it seems that we are little bit exaggerating With the pursuit of visual perfection, which did not exist in practiceWhether it's five or twenty deadeyes you need to align, it is a tedious job at best.
(I wonder if they would have been so perfectly aligned in the old days as we model them to be...)
Unfortunately, I am all too ware to that fact: struggling with it every day.Other reflection : don't forget that modelling an ancient wooden ship in reduced scale is always a transposition, never a simple copy![]()
I understand. Still, the strains on the shrouds and lanyards, the variation in material properties of the ropes could result in uneven elongation, while under load.I think you're losing sight of the fact that in reality, at 1/1 scale, it was quite simple to correctly align the deadeyes (and also orient them) so that the lanyards of shrouds were parallel without touching each other to avoid premature wear, the problem we have is that we operate at 1/72 scale and everything becomes complicated by this reduction, without betraying the impression produced by the ship seen in real size![]()
