I search the forums for Jig and no results appear so I am wonder where can purchase a jig for medium to large wooden ships.. and I suppose the answer from 9/10 people will be build your own?
**VIEW THREAD HERE** |
no - there are different jigs available, but it really depends what the jig shall do?.... the answer from 9/10 people will be build your own?
Yes but I am just making the transition to wood kits from plastic... I bought a kit from Artesania Latina is the Belem @1/75 scale.no - there are different jigs available, but it really depends what the jig shall do?
Are you planing to build POB (plank on bulkheads) models ?
Did you see also this actual topic?
Hey guys, need your help finding a good building jig
I am in search of a very sturdy building jig for my 1:200 & 1:350 ships. The jig needs to have the ability to adjust length and tilt both ways. The ones available are cheap and don't have enough stability to hold enough weight to be useful. What are you guys using to build large kits? TIA! Jimshipsofscale.com
I purchased something called a professional building slip from Hobbyzone:Yes but I am just making the transition to wood kits from plastic... I bought a kit from Artesania Latina is the Belem @1/75 scale.
It does have planking and looking for something to square bulkheads etc.
Thanks I believe that is made or was by Billings.. any idea the best place to purchase from Canada... I see on ebay and they likes?I purchased something called a professional building slip from Hobbyzone:
No idea where to get in Canada. To tell you the truth if I can't find something at https://www.greathobbies.com/ then I go international.Thanks I believe that is made or was by Billings.. any idea the best place to purchase from Canada... I see on ebay and they likes?
Thanks I did figure that out as well that they are not the same!I noticed that Billings has a slip as well. If you type in building slip on the GreatHobbies website, you should see it. It's not quite the same as the one I have shown, but I would imagine it works as well maybe?
This one is Polish, NOT Billings. I made my own based on it.Thanks I believe that is made or was by Billings.. any idea the best place to purchase from Canada... I see on ebay and they likes?
By now they probably have Lego in Antarctica. When they step on a piece in the middle of the night it reminds them of home.I think you have Lego in Canada?
You could use Lego-bricks to get the bulkheads square.
