Hull planking continues...
Good luck edge-bending a plank like this:
As I got tired each work session some of the planking suffered for fit - but nothing that will ruin the hull. I can't wait to sand it out and see what we've got!
Good morning Paul. The feedback from the guys is so informative. It supports your studies and build design (you got this spot on Paul)- thanks for the learning guys. Your treenails look so good pre sanding - you must be pretty chuffed right now and my fear of the contrast colour has not materialised. Simply wonderful work. Cheers Grant
My research for top and butt planking says, "for strength." But it will take someone with a deeper pool of knowledge to explain why...
Here is what P. Goodman said about the hull planking. Sorry, I didn't want to type so make a photo.
Hope this will help.
Thanks, Paul and Jim for replying.
Absolutely not intending to be patronizing, but with my limited knowledge about strength and stiffness this isn't a very convincing reason to me. In itself, at plank level, you do increase the vertical in-plane bending stiffness, but as a whole, on hull level, it is the total moment of inertia and derived bending stiffness being decisive for the rigidity of the hull. Interesting, to say the least.
Thanks, Grant. I'm afraid they will darken under finish... I may try a sanding sealer before the poly to mitigate that.
Hello,
I am not sure if it was already mentioned, but what did you use for treenails? Just regular toothpicks? I think I am going to try putting treenails on my Constitution, and was wondering if ordinary toothpicks would work? maybe have them stained first?
Paul knows how to drill holes and fill them up, it won't hurt at al.
Ha! If I drill into a tooth it is most certainly going to hurt. Orthodontists don't have/use any anesthetic!
I have learned from Paul, one day, that dentists are not orthodontists. They don't drill holes they make them even... ROTFROTFROTFROTFROTF Perhaps, what do I know?
:D:D:D Yes Jim!!! It turns out that you ARE teachable! Dentists are not orthodontists, and orthodontists do not do dentistry (though to be an orthodontist you have to first be a dentist).
Hello,
I am using boxwood that began as a 1x1 mm strip and then pulled through a drawplate down to my preferred size. It seems that most everyone uses toothpicks though.
thank you. appreciate the prompt response. I still have a lot of time before I start this next project, but I am trying to get all my ducks in a row, so to speak. I am even thinking of putting sails on that boat. My first time. Should be exciting...
