My research for top and butt planking says, "for strength." But it will take someone with a deeper pool of knowledge to explain why...One for the knowledgeable ones among us; what is the rationale behind these pentagonal planks, other than that it looks nice in a strange kind of way?
True story. I am sure your "ruined" is many peoples' "awesome".
Good morning Paul. The feedback from the guys is so informative. It supports your studies and build design (you got this spot on Paul)- thanks for the learning guys. Your treenails look so good pre sanding - you must be pretty chuffed right now and my fear of the contrast colour has not materialised. Simply wonderful work. Cheers GrantHull planking continues...
Good luck edge-bending a plank like this:
As I got tired each work session some of the planking suffered for fit - but nothing that will ruin the hull. I can't wait to sand it out and see what we've got!
Thanks, Paul and Jim for replying.Here is what P. Goodman said about the hull planking. Sorry, I didn't want to type so make a photo.
Hope this will help.
A very nice detail but oh so many treenails, I don't think my patience would allow this.Hull planking continues...
Paul knows how to drill holes and fill them up, it won't hurt at al.A very nice detail but oh so many treenails, I don't think my patients would allow this.![]()
I have learned from Paul, one day, that dentists are not orthodontists. They don't drill holes they make them even...Paul knows how to drill holes and fill them up, it won't hurt at al.
Perhaps, what do I know?I reject that last statement...you built a hull with a staple gunPaul, it looks fantastic!! You, sir, are a braver shipwright than I will ever be.![]()
.Thanks, Grant. I'm afraid they will darken under finish... I may try a sanding sealer before the poly to mitigate that.Good morning Paul. The feedback from the guys is so informative. It supports your studies and build design (you got this spot on Paul)- thanks for the learning guys. Your treenails look so good pre sanding - you must be pretty chuffed right now and my fear of the contrast colour has not materialised. Simply wonderful work. Cheers Grant
Yup. Just doing about a third of the hull took a full week.A very nice detail but oh so many treenails, I don't think my patients would allow this.![]()
Ha! If I drill into a tooth it is most certainly going to hurt. Orthodontists don't have/use any anesthetic!Paul knows how to drill holes and fill them up, it won't hurt at al.
I have learned from Paul, one day, that dentists are not orthodontists. They don't drill holes they make them even...Perhaps, what do I know?
I am using boxwood that began as a 1x1 mm strip and then pulled through a drawplate down to my preferred size. It seems that most everyone uses toothpicks though.Hello,
I am not sure if it was already mentioned, but what did you use for treenails? Just regular toothpicks? I think I am going to try putting treenails on my Constitution, and was wondering if ordinary toothpicks would work? maybe have them stained first?
thank you. appreciate the prompt response. I still have a lot of time before I start this next project, but I am trying to get all my ducks in a row, so to speak. I am even thinking of putting sails on that boat. My first time. Should be exciting...I am using boxwood that began as a 1x1 mm strip and then pulled through a drawplate down to my preferred size. It seems that most everyone uses toothpicks though.
The first thing I was thinking about is that a 'first-dentist-then-orthodontist' would for sure use toothpicksI am using boxwood that began as a 1x1 mm strip and then pulled through a drawplate down to my preferred size. It seems that most everyone uses toothpicks though.
And you enjoy that?If I drill into a tooth it is most certainly going to hurt. Orthodontists don't have/use any anesthetic!
