Uses for an old cutting mat
All the fuss about the color of a mat can partly be traced back to our American friends: They introduced the music style 'BlueGrass'. It shouldn't get any crazier....... :mad:
Grass is green under normal circumstances, if it turns brown then you have a problem, as does if it turns yellow. But I have never seen changing it into blue …….
Fortunately, Kurt @Kurt Konrath already brought photography into the picture with the composition of light and its influence.
A Blue mat is also a Green. With just a little too much Red in it. :) (If we talk in the same standerd RGB language….. ;))
Here at the sea we also have the colors SeaGreen and SeaBlue. And they are exactly the same.:)
So with What You See in real of mats Is Not What You Get on the photo. You cannot depend on a color on YOUR screen. WYSIWYG is not correct, it's WYSINWYG.
And if it wasn't something like that, then it wouldn't be like that... that's how it is.
I could be green and yellow annoyed and turn red in the face. But I just cut into every mat I come across until I'm left with blue fingers.
No MATter what color the mat has.
I think he doesn't have a green mat. ROTF
Cutting mats must be green not blue. Oysters are blue, you can't cut on them. Singing yes a real cult, but not cutting.
Wrong, Stephan. You have to cut IN them, otherwise you can't eat them. And you also cut IN a mat when using it. When you cut only ON a mat, you can put your 16 mats aside and just cut ON your table.
So, Not a valid argument! Blue mats are still in use ....... :)
