Have you thought about using pro video camera batteries that are 14.4 volts and only weigh about 1.5 pounds each. They’re considerably less expensive and they are LiOn. You’d have to modify the brackets and probably connect them in series or use a step up transformer? Just a thought.Motors are Ride on Scooter motors that require 24 volt batteries to run, here is one while I fit the mounts which will be glassed in. The prop shaft is continuous from the motor room bulkhead to the prop itself which makes the A bracket visual only, the shafts are totally to scale but enclosed over whole length so luckily it was possible on this ship, basically its the same setup as a smaller model, a shaft with bronze bearings at each end and a grease nipple in top.
the rest is all visual to make it look proper.
I was going to use 4 x12 volt batteries about 8 AH but am considering Lithium packs now, just scared of fire risk...not to mention 24v Lithium batteries are between $1000-2000 each.
Believe it or not the finding the batteries has been the hardest part of this build for me..so if anyone has suggestions please shoot.
Here are the motor specs.
I should add the motor specs were given to me by the guy who built the props, as I am not great at that sort of thing.
XYD-6B 450W 24V DC Motor - High-Power at 2600 RPM with Chain Sprocket
Upgrade to high-power performance with the XYD-6B 450W 24V DC Motor. Features a Chain Sprocket for efficient and reliable operation at 2600 RPM.www.motiondynamics.com.au
H
I wonder how that would perform over time with the load on it, weight is not an issue, I have 80kgs to make up in ballast.......
Thanks, I will see if i can find out about this info.Good luck with this project, I’m going to be eagerly awaiting the ship’s launch!
I totally agree about having a wonderful wife. Your pond is impressive. Your copper work is also impressive. I only recently started working with PEB, it’s been fun learning how not to do something. I’m a firm believer in learning something new every day! I get lots of inspiration here on SOS, hopefully I remember what I learned and put that knowledge into practice.Thanks, I will see if i can find out about this info.
Yeah its going to be a bit of a deal when it goes in the pond the first time, even my dentist has asked to be there. we built a water feature onto our house last year, it's a "pond" with a waterfall at one end, and good for dogs to cool down, the fact that it is 5.5 m long and 800mm wide is complete coincidence I promise..... yeah no it's also a test tank. I can avoid any embarrassing problems now before that day
What to do if the bath is no longer big enough!
As I said, having a wonderful wife is a big help.
Richard,Included in Hull kit so far, and this will change
All cut frames with internals left in for scrap
Keel, Deadwood, stem and sternpost, mast steps and knightheads
The tween and main deck, all the counter frames and parts for the saloon.
The longitudinals on the decks and bilge stringers
Paper templates of the frames for bevels and of the rabbet.
The deckhouse carcasses
The main rail, Topgallant rail, break of poop plank and break of foredeck plank
The catheads with sheave slots cut in
The plates for the counter and bulwarks from ply and aluminium with washports and hawse pipes cut in
The topgallant vertical rail
Cnc cut decorative mouldings for the panelling. Estimated box size approximately 900mm x 500mm wide and 150mm deep
I need to find out about the whole bring wood into countries thing. When I moved to Australia from New Zealand in 2000 I had have all my guitar making wood fumigated.
Did many overnight sailings Wellington to Lyttleton and returns on her. Most enjoyable and some fairly rough Cook Strait crossings but all fun when one is a teenagerI have been building this model for 2-3 years now and had a build on another site but due to requests I have decided to do a build of sorts on here as well but will spend some time just getting everyone up to speed as its a complex build and lots to grasp.
This is not for the faint hearted,
First off the most common questions I get .
Why this ship
Because she is a stunning looking ship and has ties to my family and personal history. also I was presented with a very unique opportunity to catalogue all the Union Steamship Company plans for the archives and also had some left to me my the designer of the ship so in a trade I gave them mine in return for what they had.
In short I have over 400 actual shipyard plans and hundreds of slides and photos from the archive and personal collections.
Why so Big
I have in the past built a number of hulls for test tanking use for naval Architects and wanted to have a model that behaves on the water correctly and starts to produce a wake and bow wave correctly, so doing it at test tank size seemed logical, I know many will question my sanity on this.
The other reason is when you have soo much detail on a ship that you don't have to guess anything you need to or owe it to the job to do it right and in my opinion to get it all in it needs to be a large scale.
I don't live far from my local model boat club lake (5min drive) and will have a custom case and trailer made for it.
OK the ship
She was the largest RoRo vessel of her time built in 1964-65 at Fairfield's in Govan Glasgow to do the Wellington Christchurch run in New Zealand she foundered in 1968 with the loss of 52 lives due to being caught in a cyclone and overwhelmed.
My parents worked for the USSC who owned her and my father built a couple of models of some of their ships for the company.
The research involved in this project has been over 10 years of my life and goes as far as getting samples of paint from artefacts from the ship and getting it analysed and the paints reconstructed and made, painted out to fade and then matched to a model friendly form.
I found the masts in 1985 and had them conserved so was able to get that colour that way.
The models my father did were painted from the paint in the ships paint lockers, so was able to find those at Otago Museum in NZ and get those colours that way, the rest were in the paint spec document for the ship.
I will put up some images of the model as it is now and will then cover it in sections, like interior spaces, running gear etc
Steelstring Acoustic, Classical and Archtop Jazz, I studied under a guy in my younger years after I left school.ou’ve mentioned that you build or built guitars? What type? My son and daughter in law are both very talented musicians, my son plays guitar…. Electric and acoustic, piano and keyboard… he’s adept at playing most styles: rock, jazz, pop, etc. His wife also plays piano and guitar and sings. Me…. At this stage I play audience and videographer and photographer. My wife…. Well she’s an inspiration to us all… she sings, plays piano and is one of the best tv journalists I’ve ever worked with. Long 43 year story!
Sadly I missed it, I was born in 1971Did many overnight sailings Wellington to Lyttleton and returns on her. Most enjoyable and some fairly rough Cook Strait crossings but all fun when one is a teenager
I wont photo bomb but here is a couple
View attachment 418633They look like Gibson’s. Beautiful guitars. Scott’s got about 8 guitars at this point. Gibson is one, the rest are a variety of Fenders. I’ve been threatening to buy him a Dobro or a pedal steel for his birthday but since they have a brand new musician, only 7 months old, he probably won’t have time for a while to get proficient for a while.![]()
Yes I have a trailer designed ready to get built, the lake where this will run is not far from here luckily, 5km or 3 milesWould you need to build a custom trailer ?
