Workshop ideas/layout
First Project in the new workshop.
Jean Boudriots' "Bonhomme Richard 1779 came in yesterday!!
Fooled you!
I just ordered the ZHL Bonhomme Richard Pear Cross Section, Top Level. Should start a build log sometime in February.
Phot is actually a shop break in project. I'm building custom louvers for four windows in the basement. The wood is awesome. It is alder planks 1/4"x1.5"x24", from Swaner Hardwoods in Los Angeles (ordered though Home Depot). Milling is excellent and the grain, color and uniformity is good enough for a quality scratch build!
Here is the first window louver completed.
You can’t do quality work if you have to keep chasing the part that you are working on around the bench. There are also tools like a hot soldering iron that you don’t want to show up in unexpected places. Don’t ask me how I know this!
So! When I remodeled my shop several years ago, I installed a number of the brass inserts posted in the first photo in a grid pattern into the top of my workbench. These thread into a drilled hole. The inside is tapped for a common 1/4” NC machine, screw. I would assume that are, also available for metric sizes too. They are not expensive.
The second photo shows a brass part captured under a strip of modeling plywood and fastened to a scrap of MDF. Fastened to the bench top it is waiting to be soldered.
The third photo shows a cheap soldering iron holder fastened to a plywood base which in turn is screwed down to the bench top.
Roger
Nice. I have yet to figure out the best work station layout for ship modelling.
Roger
Brilliant! Not sure if this would be practical for my tiny bench, but I may try it anyway.
