- Oct 9, 2020
wow. very impressive. Question. How fine do you go with the sanding? 400 grit?
Never less than 320. More if it warrants it.wow. very impressive. Question. How fine do you go with the sanding? 400 grit?
Hi Christian, where should I be adding trenails? (I was going for a simplified look but wasn't intending to leave off something obvious.)You forgot the trenails on the planks. Have you tried to make treenails out of holly? The contrast is in my opinion to big
Oh, I understand now. I need to make more trenail stock - something has happened to my drawplate and I can't get past hole 28 (Byrnes) which leaves me with 0.7 mm trenailsbut did not install treenails in the planking /holly).
So this is the fuss it was all about. See, it wasn't so painful. Finally I can say it to a dentistHere is where we were on the aft platform before my digression into figuring out how to cut pockets for carlings and ledges...
The opening at the bottom of the picture is a scuttle that leads to a fish hold (or on some later ships a spirit room). I wanted to represent half of the hatch leading to that space. First, I needed to make a faux hinge by soldering a bit of brass wire to a PE hinge sourced from my Vasa kit.
Trimmed up, burnished, and placed on the half-hatch:
Not great, but good enough for something you won't be able to see.
And while I was burnishing something I added some brass sheaves (these were purchased but had to be sanded down to fit the 1 mm slot in the fixed block):
Here is the final appearance of the aft platform:
There should be some bulkheads/dividing walls under the platform but I'm leaving them off.
I had to take several shots are the forward platform(s). I struggled here. The geometry of the platforms and the geometry of the interior hull would not cooperate and there were some wasted hours. In the midst of my struggles I failed to take progress photos, but here is the final result:
Nothing has been fixed in place so there are some minor alignment issues. There are things above these platforms that need to align with the platforms, so I'll postpone glueing anything down for a few months...
Thanks for the visit!
It looks like a jig-saw puzzle to me Paul. And not your common-or-garden type of jig-saw either; rather the 3D, mind-boggling 10,000-piece variety that can drive you nuts. Every addition you make to your Kingfisher is a joy to watch, well doneI had to take several shots are the forward platform(s). I struggled here. The geometry of the platforms and the geometry of the interior hull would not cooperate and there were some wasted hours. In the midst of my struggles I failed to take progress photos, but here is the final result
I’ve just arrived at post #883. Along the way this build log is filled with innumerate superlatives. I am overwhelmed by the beauty created by this master craftsman.I returned recently to the Lauck Street Kingfisher, and it was essentially more of the same: fitting frames - cutting fillers (recall that each of these must be customized because the space between the frames is not uniform) - and installing chocks at the tops of the frames (also requiring a custom thickness).
While the glacial pace made it hard to appreciate that progress was being made - in time the frames were all in place.
I won't declare victory quite yet because I still need to add the sills for the row-ports - and then there are chocks/spacers/fillers to be placed between every third frame or so along the vertical height of the frames (still need to study the plans better to understand that part).
But I was tired of framing and anything associated with framing so I spent a few days fairing the inside of the hull. I've said it before, but it bears repeating: sanding boxwood is no joke.
Anyway, having all the frames set is a significant milestone so I'll share some images.
It's difficult to take representative photos with a full size SLR camera so I took a few pictures with my cell phone:
Anyway, you get the idea...its faired on the inside...
Hi Paul in post #1001 you say “I ended up using a small, powered drill”Hello Friends,
With the completion of the fairing, I turned my attention to the addition of trenails at the locations of the frame chocks. For anyone interested there is a nice discussion about trenails (treenails, trunnels) on Dean's build log. That conversation runs for several pages:
NORSKE LOVE - Billing Boats 1:75 scale
Nice save..Over here there's a saying about breasts and model trains; meant for kids but grown-up men are playing with them. Now this extends to Lego as well. I told my wife yesterday… the difference between a child building a model and a grown man building one, is the level of expertise! ROTFshipsofscale.com
Issues raised include wood species, material options for the trenails, what is visible at a normal viewing distance (especially inside of a case), time commitment vs ROI, even the simple fact that once one begins there is really no turning back, etc. But at the crosshairs of that discussion was the issue of scale...
Well, for this Kingfisher build, the decision to add trenails was made long ago. Factors: 1. this is a POF build, and I really wanted to showcase the construction of the ship to the extent possible, 2. at 1:48 I believe trenails would be visible when examined at close range, 3. my earlier experiments with making trenails got me down to 0.56-0.58 mm (scaled to about 1.15 inches or 30 mm) which meant I could make 'true-to-size' trenails, 4. and finally, I like the look!
First job was to drill some holes. This was easier said than done as there is very little space inside the hull (that's where I began just in case this all went tragically wrong). I first tried to use a pin-vise type manual drill but that didn't work for me: the holes were too irregular - and I kept breaking the hardened metal drill bits. I ended up using a small, powered drill and never broke another drill bit:
The hole is just a bit under 0.6 mm... Test fitting a boxwood trenail:
Glued in (PVA):
Nipped off:
I learned that I needed to insert the trenails using my fingers and not a tool. The use of tweezers (or orthodontic pliers) tended to 'dent' the trenail and caused it to snap (yes, I broke lots of trenail strips using my fingers as well). Given the difficulty of creating trenails this small you can be confident that I used up every broken scrap I could.
Here is the thickness of my trenail stock compared to a garden variety toothpick:
Anyway, here we are after installing the trenails:
And after sanding:
And with a little something on the wood to show what the trenails will look like after the addition of a finish coat of poly:
I am very happy with the size, shape, and uniformity of these trenails. I believe careful drilling, use of a draw plate to create trenail stock, and adequate sanding all contributed to the final appearance.
Next, I'll add the chock trenails to the outside of the hull - but first a short break. My bride and I are headed to Yellowstone / Glacier National Parks for some sightseeing and hiking. See you in a few weeks!
See this post for a picture:Hi Paul in post #1001 you say “I ended up using a small, powered drill”
Can you divulge what is this drill you expertly wield? Is it a dental device or something we might be able to acquire?
Thank you again for fielding my many questions and for your enthralling log.
michael
WHAT!? Now even you have turned on me Maarten?Hi Paul,
If you are not happy with these hinges you have to feel ashamed of your selve, these are near perfect. Do you really think the black smith who was smashing with a heavy hammer on a red hot glowing iron bar and punching in some holes was worried a bout a tenth of an inch. He just needed a hinge
Like a wise snowman once said " let it go ..."
It looks great.
Ps can it open?![]()
I put my arm around your shoulder! I rode in your car! I gave you a Zind Humbrecht and Dutch cheese! I thought we bonded?!?
