Hi Jfwdc, sanding is done before staining the surfaces, after stained a very fine grit is passed to remove some lumps of paint. This is my system of working, I wonder, does it have any use after coloring sanding?FrankHi, I’ve done the first coat of primer on the Norwegian sailing pram. I need to sand it…what grip is best for this? I’m glad I found out about this website!
James
Hi,Hi, I’ve done the first coat of primer on the Norwegian sailing pram. I need to sand it…what grip is best for this? I’m glad I found out about this website!
James
Maybee it's an old habit from my plastic modelling times. There I used 800 - 1500 for the primer and color layers and 3000 for the last finish. For high gloss I used up to 8000 before polishing.I have always used 220g or a fine sanding sponge to cut back primer or sealer.
In general, for woodworking, I'd advise against the use of steel wool. If there's ever any exposure to moisture, including ambient humidity, you risk rust stains on the surface of your finished product. You can achieve the same results as burnishing with steel wool through the use of extremely fine grade sanding papers (800 and higher.). But if steel wool has worked for you in the past, then stick with what you're comfortable with. I'm merely playing devil's advocate when I suggest avoiding it's use.Very fine wire wool is also useful to have to hand.
I should have explained - steel wool is good for awkward or rounded parts (masts, spars etc) because it does not knock off the edges or go too heavy in one particular place. Obviously no good for flatting. I have never had a problem with rust. Regards.In general, for woodworking, I'd advise against the use of steel wool. If there's ever any exposure to moisture, including ambient humidity, you risk rust stains on the surface of your finished product. You can achieve the same results as burnishing with steel wool through the use of extremely fine grade sanding papers (800 and higher.). But if steel wool has worked for you in the past, then stick with what you're comfortable with. I'm merely playing devil's advocate when I suggest avoiding it's use.
18,000?! You can almost polish mirrors with that…Yep!
I have 40 to 18,000 - covers most anything project wise....
do you mean 1800? I think the finest sandpaper I see is 7000Yep!
Hi, this is not sanpaper, but it is available up to 12.000 grid... Micromeshdo you mean 1800? I think the finest sandpaper I see is 7000
Start with grit 220 and adjust as necessary.Hi, I’ve done the first coat of primer on the Norwegian sailing pram. I need to sand it…what grip is best for this? I’m glad I found out about this website!
James
