- Oct 1, 2023
Thank you Daniel.Hi Ted, A=the dark shadow indicates the bevel is still not quite there yet. You should only see a thin line or what I call a knife edge against the deadwood.
B= There should not be a shadow here either, this joint should be flush.
I know. I'm trying to figure out the best way to finish this chamfer with damaging the deadwood.
On arrow B I'm going to have to cut out a bit and glue I a square piece.
, did the layup on the plans.for the first half. It came out perfect. The braced the second half using square blocks in til glue adhered. Lastly I used the clamps to provide more pressure during curling. Will remeasure as you suggested when it is cured
