- Mar 18, 2024
Hello from Tucker, Georgia. The ships on this forum are truly impressive and inspiring. I've undertaken my first build, the Lowell Grand Banks Dory. As meticulous as I've tried to be, I've managed to botch a few things up and am learning from my mistakes. Now that I have all the planks glued on, I've got to clean up some issues caused by putting too much pressure on the plank while it was drying. Should I wet the planks in the areas where they're warped out of shape and try to reshape them? If doing so, will that make the white glue I used dissolve? It's embarrassing to post the results in the picture to such an experienced group, but I've learned a lot and will likely order another Dory and try to do a better job applying what I've learned. Any advice, including yea, trash this one and start over, are appreciated.
