- Mar 22, 2024
They say the ship lost power - possibly due to dirty fuel. Is there any reason why you would not drop anchor? Or does that require engine power too?
			|  | As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering. |  |
yes, it requires electric power to drop an anchor.They say the ship lost power - possibly due to dirty fuel. Is there any reason why you would not drop anchor? Or does that require engine power too?
Amazing. Serious lack of joined-up thinking there.yes, it requires electric power to drop an anchor.
I’m sure that the chief engineer has some splaining to do. Just to use correct term … this was an allision with the bridge. Since the 1970s they have been building defensive barriers around bridges. Guess they couldn’t be bothered. There are many large cranes close to there that could get that wreckage out of the way quickly. But the “so called “ experts will talk and talk. I would call weeks marine and ask them to get that bridge out of the way. I am a retired captain familiar with that areaI am wondering if something has happened to the person/personnel that the ship seems to have gone in the wrong direction and hit one of the columns of the bridge rather than go to the middle and pass underneath it.
No power necessary. The anchors should be out of the hawspipe and held on the brake when possible manuvering. The chief mate plus one ab should be on the bow. This was law in the Panama Canal. If they were prepared they could have had 2 anchors downAmazing. Serious lack of the joinedup thinking there.d
Agreed, the master would normally require the anchor/s to be walked out and as Senorbob mentions, held on the brake, no power is required to letgo. It is usual to have two men on standby for’d to letgo the anchor if anchoring normally and also when required underway in close waters. Once the vessel is safely outbound and has dropped off the pilot/s the bosun will secure the anchors for sea. It is important to note the seamen for’d do not make the decision to drop the anchor, the order comes from the nav. bridge. Communications is obviously paramount.No power necessary. The anchors should be out of the hawspipe and held on the brake when possible manuvering. The chief mate plus one ab should be on the bow. This was law in the Panama Canal. If they were prepared they could have had 2 anchors down
In 1000 ft dredging the anchors a great amount of headway would be off . More importantly you could sheer the ship one way or the other.Question: the ship was said to moving around 8 knots... How long would it take for anchors to stop a ship that large traveling at that speed? I'm just a landlubber but I'm guessing hundreds of meters. A thousand meters? More?
You ask a good question Paul. anchoring is, under normal conditions, undertaken when a ship is stopped in the water while considering other factors such as nature of the bottom, holding ground, currents and windage. Stopped or a very, very slow speed avoids stress on the anchor cable leading to possible brake failure, loss of the anchor or the cable parting. Once the anchor hits bottom the cable is released a shackle (15 fathoms) or two at a time as the ship falls off using the brake to control the run. This is to spread the cable across the bottom to avoid it piling up too much. You can tell this by looking at the cable as the weight starts to come on, releasing more cable till it slackens, then continue until the amount of predetermined cable is deployed. The brake is then tightened hard and the cable monitored until it becomes “up and down”, ie straight down from the hawse or the weight comes on, then off, the cable as it leads away from the bow. At this point the ship is “brought up”, things are double checked (brake etc) and the vessel now lies and swings to anchor. It is the deployed cable that provides most of the holding power.Question: the ship was said to moving around 8 knots... How long would it take for anchors to stop a ship that large traveling at that speed? I'm just a landlubber but I'm guessing hundreds of meters. A thousand meters? More?
The problem with 'let it go' and using the brake is very dangerous, it can dismount the winch, and put it on fire altogether if the brake fails!Agreed, the master would normally require the anchor/s to be walked out and as Senorbob mentions, held on the brake, no power is required to letgo.
.You ask a good question Paul. anchoring is, under normal conditions, undertaken when a ship is stopped in the water while considering other factors such as nature of the bottom, holding ground, currents and windage. Stopped or a very, very slow speed avoids stress on the anchor cable leading to possible brake failure, loss of the anchor or the cable parting. Once the anchor hits bottom the cable is released a shackle (15 fathoms) or two at a time as the ship falls off using the brake to control the run. This is to spread the cable across the bottom to avoid it piling up too much. You can tell this by looking at the cable as the weight starts to come on, releasing more cable till it slackens, then continue until the amount of predetermined cable is deployed. The brake is then tightened hard and the cable monitored until it becomes “up and down”, ie straight down from the hawse or the weight comes on, then off, the cable as it leads away from the bow. At this point the ship is “brought up”, things are double checked (brake etc) and the vessel now lies and swings to anchor. It is the deployed cable that provides most of the holding power.
I mention a basic anchoring procedure because your question pertains to a large vessel travelling at speed and dropping the anchor under duress. That is a very different matter and obviously only done under emergency conditions. Bearing in mind what I wrote above about speed and stress it follows releasing the anchor at speed is a last ditch effort to rapidly reduce forward momentum. In an emergency the brake would be opened and the cable allowed to run, hopefully under controlled conditions but it would be dangerous. On such a large ship the immense stress as the cable ran at speed, hit the bottom and dragged would make it very difficult to control on the brake. If the brake could not hold then the cable would run to the bitter end and rip from the chain locker. If it held the hope is some way comes off the ship. Deploying both anchors would be beneficial but trying to provide a practical stopping distance at speed is extremely difficult to know under shipboard operational or emergency conditions.
It really is one of those hope and pray moments. But no master wants to go aground with the anchors still in the pipe.
Base of Delaware Memorial bridge. The same huge ships pass hereYes even if the accident is over sound the danger signal and drop the anchors.it takes excellent seamanship to let go an anchor underway. When the anchor hits the bottom there’s a moment when you can set the brake, then the anchor won’t set and you can dredge it across the bottom. I was forced to do this twice in my career. The chances of a third world crew pulling this off are not great. It’s possible that the master and crewman don’t speak the same language
