- Mar 23, 2024
Hello Everyone,
This is my first ever attempt at a Build Log, so please help and advise on what I should be posting.
This is the initial unboxing of the kit by Occre I received it last year and unfortunately there had been an accident by the international shippers between Occre and the UK outlet I purchased the kit from, I had pre-ordered the kit and found the kit had suffered a big enough shock to damage the wooden box break the plastic outer layer and spill most of the contents of one of the plastic containers, on notifying the UK supplier they discover more damaged kits. Occre were and are brilliant and as far as inventory goes I believe I have everything.
So here goes some pictures of the bits and pieces.
My Next task will be to find sort and label all the timber and pre cut parts.
My First Impression is that this will hopefully be a stunning naked kit as I don't think it is intended to be painted. There are many formers and gauges supplied with the kit to assist in the highest possible build accuracy this is novel as I have had not had this in any previous kit.
Thanks and regards Kenny
